Posts: 215 |
It doesnt sound like its down low, its driving me insane. Should I go to Ford?
See ad in Classifieds, Price lowered to $8,500. Buy it!
59K Miles, Original Owner, 3 liter built by Buckshot, Headers, HMS trans
Subframe Connectors, H&R's, Koni's, Rage 5.0 17's, Pole Position Tires
Removed Resonator,KKM Intake,ShoShop Y-Pipe
Posts: 5,345 |
Originally posted by plance1: It doesnt sound like its down low, its driving me insane. Should I go to Ford?
Before you do that, check that you have nothing loose in the trunk. Jack, spare tire, etc. Then do a strut test. Push down on car and let go. If it bounces more than once up and down, then it is probably a bad strut.
1996 V6 ATX 96K miles
Posts: 215 |
Thanks, but I checked the trunk, nothing doing. The struts seem fine but thanks for the ideas.
Posts: 2,659 |
Check your tires they maybe shot. Look for worn out tires.
99 Contour LX
95 Mustang GT Convertible
97 Z24 Cavalier
Posts: 1,456 |
If it happens on bumps, Sway bar hardware (links, rubber bushings). If under braking, rear brake shoes are worn out.
Posts: 154 |
If I may, I had a similar noise I think on my left rear side. I thought it was my sway bar link and bushings. After wasting most of the morning changing these I found our it was not that at all and I am still wondering what it is? Could it be the bushings on the actual sway bar itself..It is more pronounced when I have little to no gas in the tank??
1998.5 Silver Frost SVT
#4978 of 6535
160,000 miles and still going..
Posts: 215 |
Checked it out today, the right rear koni is snapped!
Posts: 1,456 |
 Which part of the strut failed?
Posts: 215 |
The top part, the shaft is just fastened at the bottom.
