Posts: 130 |
Ok. Heres a dumb question. Which dipstick should I use? I currently have a 3.0 sable in, but the head broke off and it needs replaced. Will the 2.5 dipstick give an accurate reading in the 3.0 using the most updated oil pan? If not is there another that I should use.
Posts: 611 |
You could drain all the oil and put in the recommended amount and then check the stick to see if it reads accurately. If not make your own MAX mark on the stick.
1999 3.0L Cougar: 220fwhp and 200tq
2003 VW Passat W8 with 4 Motion AWD
http://www.cardomain.com/ride/300644
PM for intrest in 3L SVT Contours, 3L swaps into your current car, Prepped 3L engines, or anything 3L related.
Posts: 2,974 |
I used the 2.5L dipstick and it was accurate.
Aaron
AKA NVS SVT
98.5 Silver/Blue SVT#4553
Yeah it's modded
98 T-Red/Blue SVT Contour Totaled 06/05/06
03 3L,VCN 2000,CAT Cams,MSDS Headers w/Y-Pipe,XCal2 and lots more
Posts: 2,097 |
I would say use the dipstick that correalates to the pan you use. 3L pan...3l dipstick 2.5 pan...2.5 dipstick.
98 E0 SVT with some stuff
Posts: 595 |
What about the updated oil pan? Will the stock dipstick measure the oil level accurately with the updated pan?
Black 1998.5
3L Oval Port
Full HMS Transmission
Lots of other stuff
Ressurected 06/14/06
Posts: 1,336 |
There are 3-4 different dipsticks out there IIRC ... let Bill Jenkins know the oil pan part # and he can get the correct dipstick/tube assembly for that pan.
Posts: 9,602 |
Just make sure you use the dipstick and it's tube as a matched set.
I used the set from my 5/02 Taurus engine and it is accurate. 6qts shows just cresting the full notch.
2000 SVT #674
13.47 @ 102 - All Motor!
