Posts: 3,867 |
Originally posted by Bradness: Originally posted by todras: Rod shift and ALL MTX's back to '95 DO NOT have ATF spec lubes!!!!
Funny, but I guess you interpret Mercon as manual gearbox lube. Even though the manual clearly describes it as "ATF"!
Let me say it again. I've been using ATF (mineral & sythetic)as specified for 10 yrs. I've had the trans apart and there is no detrimental wear apparent.
Brad,
FYI, Todd is referring to the fact that the manual has been superceded by TSB 00-1-9.
However, interpretations of this TSB differ, as I noted in my post, above.
If your MTX-75 was built after 1 Jan 2000, your spec has indeed, without a doubt, changed to the XT-M5-QS spec ("Honey").
This same spec is "compatible" with earlier MTX-75s and fluids, and "recommended" by Ford for these units, for topping off or refilling.
Todd, Terry Haines, and others point to the fluid supplier's cross-reference diagram--which makes no "early" or "late" distinction, and only lists the "Honey"--and contend that it is a "spec."
Function before fashion.
'96 Contour SE
Posts: 3,816 |
I don't know about all this tranny talk, but I know Bradness is one of those pimps that when something breaks, he creates a better one!
Still using (& abusing!) those tubular adjustable-toe control arms with zero problems!
Posts: 5,810 |
Originally posted by Big Daddy Kane: I don't know about all this tranny talk, but I know Bradness is one of those pimps that when something breaks, he creates a better one!
lol, yes He's pretty good at that stuff.
See My Mods
Posts: 1,101 |
Originally posted by warmonger: Originally posted by Big Daddy Kane: I don't know about all this tranny talk, but I know Bradness is one of those pimps that when something breaks, he creates a better one!
Indeed...I never broke any of his stuff, even some of his prototype control arms. Even Brad mentioned himself that he was suprised that at didn't break more things on my car when he came out on the track with me so he knows how hard I used to push the car and that his stuff will hold pass the test of time.
Posts: 853 |
Trans Fluids here is all you can read on fluids
98.5 Black SVT with 34k miles Build #5683 Born on 4\15\1998
WR Headers GMK CAI
Blaupunkt system fiberglass tweeter pods
L.E.D. tail lights in the works
