Posts: 173 |
its just like a warning beep or something. thats what it sounds like. doesnt sound like a belt or anything. sounds like a projected beep. it happens right when i reach a certain speed. probably around like 5 mph
Posts: 5,345 |
Originally posted by Black 98 CSVT: its just like a warning beep or something. thats what it sounds like. doesnt sound like a belt or anything. sounds like a projected beep. it happens right when i reach a certain speed. probably around like 5 mph
Turn ignition to on, not start. Is Airbag light on? When the airbag light is out, the airbag module gives a series of beeps if there is an airbag issue. The beeps (or airbag light flashing) will tell what the fault is.
1996 V6 ATX 96K miles
Posts: 173 |
hmm, im in summer school right now. but after, i'll check
Posts: 173 |
Posts: 173 |
anyone? i have to know soon. it is really embarassing pulling out of school and having that thing go off. it only happens on startup. not while ive been driving for a while
Posts: 5,345 |
Posts: 173 |
belt is fine, but how do i know which pulley has the bad bearings? i dont really want to take it all apart to find out it isnt a bearing problem
Posts: 5,345 |
Originally posted by Black 98 CSVT: belt is fine, but how do i know which pulley has the bad bearings? i dont really want to take it all apart to find out it isnt a bearing problem
Need to remove belt. Then turn pulleys by hand.
Posts: 173 |
cool, thanks a lot. i'll be back if everythings ok
