Posts: 503 |
Originally posted by Anm8: Hopefully things get exciting for Ford!!
You mean hopefully Ford's cars will stay alive. Don't get me wrong, this engine is good, but its way late and considering the complete morons running Ford, they will probally find a way to screw this up like they do most everything else.
95 LX-with a mind of its own
24v DOHC
SVT exhaust and K&N=all thats worth modding
Go Fighting Sioux!!!
Posts: 4,220 |
Originally posted by ????¯?¬?¬?º: Originally posted by Beans: man, you people are so mean
i couldnt imagine a bigger engine than a 3.0 in a contour, hell the 2.5 is big..
Someone here will do it tho...
way under powered..the Nissan VQ 3.5 is 270hp - 300hp..
... in a sportscar. You might as well be looking at the Noble M12 and say "the Ford Duratec30 has 350hp". It does, in that application.
You've got to compare application to application. The engine will debut in a Crossover, one very similar to the Murano. And what does the VQ35 do in that application? Only 245hp, putting the Duratec 20hp over it.
It will also debut in the MKZ, which would be best-compared to Nissan's Maxima. And what is the VQ rated at in that application? Just 255hp, 10hp shy of the Duratec35.
If and when the Duratec35 is put into cars similar to the 350Z and the G35 you can be damned sure that it will also be surpassing the VQ35 in those applications.
2003 Mazda6s 3.0L MTX
Webpage
2004 Mazda3s 2.3L ATX
Posts: 7,117 |
I can see a 35 in a Fusion or Milan... Add a turbo or two to the all wheel drive version & you've got a real screamer. Even the big 500 with CVT & all wheel drive & turbo or S/C would MOVE. A 35 in a Contour... If the firing sequence is similar to the Duratec 30, why not?
Posts: 21,653 |
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 785 |
Originally posted by TGO: Originally posted by ????¯?¬?¬?º: Originally posted by Beans: man, you people are so mean
yeah and they're also in cars that are alot more expensive too.
i dont think a altima 3.5 is more expensive than a 500
1998.5 Toreador Red/Midnight Blue Contour SVT - #5912/6535 - DOB - 05/11/1998 -
RU-3530/CTA Intake Pipe
MSDS Heaser/Y-Pipe
Magnaflow #10435
9mm Ford racing
SPEC Stage one/Spec Alum. Flywheel
HERE
Posts: 130 |
Originally posted by TourDeForce: I can see a 35 in a Fusion..
Fusion SVT 3.5l
Thats sounds pretty damn good to me!
'98 2.5L Mystique LS T-Red
Posts: 785 |
Originally posted by Beans: Originally posted by TourDeForce: I can see a 35 in a Fusion..
Fusion SVT 3.5l
but... SVT is dead....
MSDS Heaser/Y-Pipe
Magnaflow #10435
9mm Ford racing
HERE
Posts: 225 |
but....not according to the latest...
once again the story has changed and supposedly SVT is not dead. They just might have a slightly different future philosophy. Who knows till they actually do put something else out.
99 csvt
68 cuda fastback 340
00 gp gtp (wife)
01 gs500
Posts: 225 |
for example see this article
99 csvt
00 gp gtp (wife)
01 gs500
Posts: 3,143 |
Some of you guys need to put down the Ford Kool-Aid. You're off popping bottles of Moet because Ford catches up with the competition. With their constantly shrinking marketshare they need to do something besides play catch-up.
"Bros before Hoes" <-- More men need this mentality.
