Don't worry about the AC pulling voltage when you turn it on, more likely the voltage is dropping because the rpm is dropping when the car tries to stall. Chances are the car is stalling because it's not tuned right. Fix that and then worry about the voltage when AC is on.
Also, check resistance on your starter cable and examine it for corrosion, or check your batter because 9 volts is pretty low.
Don't start riggin the stuff, fix it right by checking the correct stuff.
See My Mods
