Yes it will warp and could rip the mounting plates on the subframe with a 21mm. If the subframe show more sign of age, there is a greater risk. Even the brackets (usally go first) I do only street.
In my case even after beefing up the subframe, it still wanted to pull the brackets out (the subframe wasn't getting damaged after it was beefed) but even with new brackets to link the swaybar to the subframe, it was pulling the tab side out.
Maybe I got a bad batch of bushings, but when I had the 21MM in it seemed the bushing was too large for the bracket. And also it was so tight around the swaybar that it would always push the grease out, it was always bad to where the bar wouldn't pivot up and down by hand, until after a regrease. Finally I stepped down to 19MM, stock was 17mm.
If you want to run 21MM I would think about getting ahold of bradness and talking about the 4bolt swaybar to subframe mounts. You could be looking at 200-300 shipped but well worth it. That is if he can find a good one in the junkyard for ya.
There seems though people have different results. So think anything over first.
I should say, try it first, if you have problems then you know you have to do more work.
