Posts: 25 |
I overtightened the bottom left corner of the valve cover. It [censored] snapped! What do i do.
Posts: 6,910 |
buy a new one  or find a used one  there was a SVT set on ebay
- 95 Mystique LS - Zetec/5spd
Posts: 3,637 |
Originally posted by Ifordman98: I overtightened the bottom left corner of the valve cover. It [censored] snapped! What do i do.
OHHH SNAP!!!
230.2 WHP @ 6500
237.0 WTR @ 2250
much like your weiner.
Posts: 25 |
Sorry i said that in a weird context.. The actual screw snapped inside the head the actual valve cover is fine.
Posts: 5,345 |
1996 V6 ATX 96K miles
Posts: 344 |
If the bolt snapped off nearly flush with the surface of the head you may be able tap it out with a nail set or other sharp pointy object. If you tap a little off center on the screw, you can make it turn a little bit at a time. You just need a little bit, then grab and twist with locking pliers. I know it's a small screw but give it a shot.
Posts: 1,017 |
and use a torque wrench next time!
1995 SE
2.5L V6/MTX
187k
Posts: 1,746 |
Originally posted by platinum_drew: and use a torque wrench next time!
Yea right! I looked up the torque specs and posted them for you, for a reason! You don't need to tighten the $#!T outta them. 10Nm, say that with me, 10Nm.
2000 Contour SVT
SF - #542 of 2150
Posts: 6,791 |
Originally posted by posthuman63t: 10Nm, say that with me, 10Nm.
Or 7.37561 ft/lb or 88.5075 in/lb
Posts: 217 |
Possibly use a drill and tap set available at any hardware store.
2000 svt contour
1996 oldsmobile eighty-eight
