Posts: 137 |
What is the best way to get this pully off? There is a hex head on the end of the shaft and one right outside of the rusty balancer. It wants to strip instead of turning and my impact is not strong enough to get the outside one. Any help would be great - I did search of crank pully and other related stuff.
1998 Contour SVT Black w/ Blue interior
Torsen LSD updated shiftforks
Lightened Flywheel, HD Drivelines
Optimized Thottle Body
2003 3.0L engine upgrade (Soon to be)
Posts: 595 |
I believe that it is a reverse thread. Righty-loosey, Lefty-tighty.
You can take a sawzall to the shaft so that you can remove the pulley and put a socket on the end of the nub.
Black 1998.5
3L Oval Port
Full HMS Transmission
Lots of other stuff
Ressurected 06/14/06
Posts: 2,097 |
98 E0 SVT with some stuff
Posts: 137 |
Thank you for the advise. Sounds like a good idea to cut the shaft.
I thought about trying reverse, but didn't
Learned patience the hard way
Posts: 2,454 |
I've had good luck just using an impact on the outermost hex portion of the pully assembly and if needed adding a little heat to loosen the loctite holding it to the crank pulley. This eliminates having to sawzall through that center shaft.
Rick
Owner of 00 #1611 Silver (Totalled) 98.5 T-Red SVT #6180
Buckshot77@msn.com
Misc 3L parts for sale
Posts: 1,746 |
Don't be afraid to cut it though, its not like you need the pully. Pray you don't have to do what I did...I had to cut the pully down to the hex and still couldn't get it to budge...and that was using a 3 ft bar on top of a breaker bar. I wound up using a cut-off tool and cutting the bolt into 6 pieces (pie or pizza style) and that loosened the bolt enough to get it out.
2000 Contour SVT
SF - #542 of 2150
Posts: 595 |
Originally posted by posthuman63t: Don't be afraid to cut it though, its not like you need the pully. Pray you don't have to do what I did...I had to cut the pully down to the hex and still couldn't get it to budge...and that was using a 3 ft bar on top of a breaker bar. I wound up using a cut-off tool and cutting the bolt into 6 pieces (pie or pizza style) and that loosened the bolt enough to get it out.
Same here. It sucked mucho.
Black 1998.5
3L Oval Port
Lots of other stuff
Posts: 587 |
Originally posted by muntus: Originally posted by posthuman63t: Don't be afraid to cut it though, its not like you need the pully. Pray you don't have to do what I did...I had to cut the pully down to the hex and still couldn't get it to budge...and that was using a 3 ft bar on top of a breaker bar. I wound up using a cut-off tool and cutting the bolt into 6 pieces (pie or pizza style) and that loosened the bolt enough to get it out.
I got away with a 3ft bar on top of the breaker bar. Hmm looks like my muscles won
3L process done
Posts: 3,732 |
my impact gun took it off in about 2 seconds on the last 3L i tore down
Russell
Oval Port 3L Nearly Done
Posts: 1,746 |
Originally posted by bradSVT: Originally posted by muntus: Originally posted by posthuman63t: Don't be afraid to cut it though, its not like you need the pully. Pray you don't have to do what I did...I had to cut the pully down to the hex and still couldn't get it to budge...and that was using a 3 ft bar on top of a breaker bar. I wound up using a cut-off tool and cutting the bolt into 6 pieces (pie or pizza style) and that loosened the bolt enough to get it out.
What are you trying to say? hehe. Anyways, I tried, my cousin tried (about 260) and my friend [censored] aka big ryan aka ryan tried and hes a good 380. And it wouldn't budge. So, the cut off tool became my new friend....
2000 Contour SVT
SF - #542 of 2150
