Page 1 of 5 1 2 3 4 5
Dude Offline OP
WE ARE TRYING TO GET A LIST TOGETHER TO MAKE A FORMAL COMPLAIN TO FORD.
PLEASE CONTACT DUDE OR COORS with the following info:
NAME & EMAIL ADDRESS you can be contacted at.
YEAR OF CONTOUR
PROBLEMS YOU HAD/HAVE With Motor/Ford Dealers.
LOCATION(City, State)
Please give as much detail as you can.
Thanks,
Brian
Brian D. Passaro
1998 Contour SVT
E0 Silver Frost #3734 of 6535
(Died 10/31/01 Reborn 02/03/02)
Superchip(Removed)~Firestone Firehawks SZ50 215/45ZR17 on 17" Borbet Type T's~ASP Underdrive Pulley(Removed)~75mm Pro-Flow MAF(Removed)~Mobil One 5W-30 Tri-Synth~Resonator removed~Flowmaster DeltaFlow '40' series dual mufflers~KKM Air Filter Induction System(Removed"Lost at FORD Dealer")~2.5-inch custom cat-back exhaust system w/ reduced angle Y-joints~4-inch rolled chrome twin-tipped exhaust tips~Konig V-racing aluminum BTCC-inspired rear wing~Sylvania Blue headlamps
EMAIL ADDRESS: mamisano@optonline.net
YEAR OF CONTOUR: 1998 E1
PROBLEMS YOU HAD/HAVE With Motor/Ford Dealers: Motor knock @ 42K miles. Replaced under extended warraty.
LOCATION(City, State): Deer Park, NY
1998 SVT Contour E1, Black
2001 Honda SuperHawk VTR1000F
"I bent my Wookie"
www.mamisano.com
Might as well put our info up here also Brian.
Chad Stroven
jetski@mindless.com
1998.5 E1
Engine Blew 41K
Engine replaced out of warranty but Ford split the cost with me $3250 out of pocket.
Shamrock Ford, Dublin California
Chad
http://www.1dzine.com
jetski@mindless.com
98.5 SVT ? KKM Tru Rev ? Glasspack instead of resonator ? Dyno Max Super Turbo Muffler w/Brospeed 3.5" Rolled tips ? Brembo/KVR Cross Drilled Cadnium Front Rotors and KVR Carbon Brake Pads ? Blown Engine Replaced @ 41K
Brad Noon
bnmotorsports@msn.com
'99 SE Sport V6 MTX
Spun rod bearing on number 5 cylinder at 47,000
$800 out of pocket, replaced short block myself with salvage yard 3 liter.
I don't trust the area dealers with a hubcap 'cus they broke two of mine. mad
Brad Noon
'99 SE MTX
3 point oh my God H.O. 179HP/178TQ
BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc
BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!
Eric Flecha Eric@RitterPenUSA.com
1999 contour svt engine blew
#206
Galloway Ford, not under warranty
Fort Myers, FL
replace engine with 00 svt motor..
approx cost...3 grand
First I would like to congratulate my 2002 "The Perfect Storm" undefeated National Champions MIAMI HURRICANES*1999 Ford Contour SVT #206 00 SVT motor with Return fuel*Black-Tan*Cold Air Intake with 6" S&B Funnel Ram*Sho-shop off road y*Brullen Cat-Back 3.5" slant tips no res*Unorthodox racing crank pulley*Lotec Guage pod with Air/Fuel, Oil Pressure and Voltage*17" Image Tuners*215/40 Falken Ziex's*
B/M Short Shifter*Nokya 9006/9005 80w/100w Xenon's*JSP wing*BNM White Faced HVAC*Custom svt emblemed rear*Bosch +4's*H/R springs*Euro Sidemarkers.
Eric@ritterpenusa.com Centerforce Dual Friction Clutch and Fidanza Flywheel.
Dude Offline OP
DEAD!!!!
Brian D. Passaro
1998 Contour SVT
Steve Holland (sholland991@home.com)
1999 SVT
Engine knocking, terminal engine failure (according to dealer) Took 3 months to get the engine from Ford.
Crestwood, IL (now)
-Steve
'99 T-Red SVT #102
sholland@svtperformance.com
www.svtperformance.com
Search?
Dave Bland
spicyminiflea@yahoo.com
1998 E0
Lawrenceville, GA
Engine locked up after 52k miles. Being replaced under warranty from dealership i bought from...not Ford
"this world has nothing to offer, come back soon."
luti-kriss
throwing myself
an act of my own violation
'98 Black SVT- 3949/6535 8k miles ticked away, Eibach springs, Koni Struts, SHOShop CAI, Ford 9mm racing wires, deleted res., lead foot...more to come.
http://community.webshots.com/user/svtminiflea
Antonio Wright
Wright_Antonio@Hotmail.com
98 SVT
Rod put a hole in the block.(I think) 45k
Car is now totaled.
99' SVT
86' Toyota Pickup Beater - Tha Daily Driver
jason.fullerton (at) verizon.net
1998 E0 SVT
86000 miles
don't know what exactly was wrong, but a piston (forget which one) had LOTS of lateral movement in the cylinder (dealer - John Kennedy Ford, Conshohocken, PA - diagnosed as "bottom end knock" and once torn down I played with the piston myself - definitely terminal)
Um, I did all the stuff in my sig to fix it.
Although, I don't think Ford is really gonna do squat. "Warranty is 36/36 and we've fixed every one that broke under warranty." Good luck.
