It could be wiring harness, or bad battery cables. I suggest you check the wiring which goes below the Power Distribution Box first. That has been known to go loose and cause an intermittent no start.
Edit. Battery is low or wiring is loose (loose not necessarily at the battery terminals. Could be loose at the other end. Check all the wiring from battery to alternator and to ground). In addition, red is positive terminal and black is negative terminal.
Test battery. Engine off, lghts on for 1 minute, then voltage across battery terminals should be 12 to 12.5.
Test alternator. Engine running, voltage across battery terminals should be 14 to 14.5
Loose wire issue.
Originally posted by SetiRich:
Ok, it's 2.5 years later, and I had the problem again...bye-the-way, I fixed it the first time...
There is a small black wire that loops up between the battery & the air filter box. This small wire attaches to a connector at one end, and seems to follow the "main" positive wire to where-ever it goes...haven't followed it.
The end that connects to the connector...is in with a group of wires that comes off the "secondary" positive terminal...this is sort of an extension to the main terminal. Both the pos & neg have these "secondary" connection posts...I guess because they needed more places to connect things close to the battery.
Anyway, the small black wire keeps coming out of the connector end. It's a PIA to get at...you have to remove the battery & battery box. Last time it just seemed to stick in there, so I left it. This time, I'm taking the battery stuff out and fixing it "for good".
I figure this must be something going to the solinoid, since there is no clicking or anything when this is out...and all light's, are great. New battery too...whenever it just doesn't start, I push it back into the connector & off I go for another 5-6 months. Guess it's nice weather again so time to fix it right.
Rich
