Posts: 6,791 |
Anyone have anymore information on this?
TSB data for: 1999 FORD CONTOUR Bulletin Number: 15830 Sequence Number: 637575 Date: 20020401 Component Name: 111000 ELECTRICAL SYSTEM:BATTERY Make: FORD Model: CONTOUR Year: 1999 Summary: BATTERY LAMP ON, HOWEVER THE CHARGING SYSTEM IS FUNCTIONING PROPERLY. *TT
Posts: 7,100 |
Probably just a dealer fix, performing the "wiring fix" outlined by GoldenTour (IIRC).
Search for his how-to.. Tony2005 has posted the link to that how-to many many times, even recently (one month?)
re-wires the small reference wire from the alternator, etc.
'99 CSVT - Silver #222/276
Posts: 7,100 |
LOL...
Didn't I just add that to the maintenance FAQ (in the last two weeks or so?) LOL.. I'm losing it.
Posts: 6,791 |
I was hoping it was something else. I've seen that fix many times and I do not think it applies to me.
Posts: 5,345 |
LOL. Yes, you did. Just one day before I posted that it should have been stickied. And there it was. I guess I should read the updated FAQs every now and then.
Rawburt, what makes you think your issue is not the same?
1996 V6 ATX 96K miles
Posts: 7,100 |
Truth be told, I added it the same day.. after reading that you said that. YOU prompted that.
Posts: 5,345 |
Originally posted by Ray: Truth be told, I added it the same day.. after reading that you said that. YOU prompted that.
ROTFL. You sneaky bum! I thought I was losing it.
Posts: 6,791 |
Originally posted by Tony2005: Rawburt, what makes you think your issue is not the same?
Because that problem seems to represent a battery light issue at low RPM and a flickering issue (which i seem to have). My problem I am concerned about is a battery light coming on at HIGH RPM that trashes out my alternator, or so I think. So far, battery light has represented bad alternator. AND, means I have done 3 alternator swaps in 3 weeks
Posts: 5,345 |
Originally posted by RawBroken: ... So far, battery light has represented bad alternator. AND, means I have done 3 alternator swaps in 3 weeks
Maybe time for a new alternator from Ford. (not remanufactured, not aftemarket).
www.teamfordparts.com
