Posts: 7,100 |
Originally posted by Tony2005: ROTFL. You sneaky bum! I thought I was losing it.
bwahahaha.. I went from revered to a sneaky bum in one minute!
I almost beat the record for CEG!
'99 CSVT - Silver #222/276
Posts: 5,345 |
Originally posted by Ray: Originally posted by Tony2005: ROTFL. You sneaky bum! I thought I was losing it.
No, you are still revered. A revered CEGer and sneaky bum.
Edit. RawBurt, check Pin connectors (and wiring below) for Fuse 5 (Fog lamps) at Power Distribution Box again. You are going to kick yourself in the "Burt" if that was the problem all along.
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=trouble&Number=1117877&page=&view=&sb=5&o=&fpart=all&vc=1
1996 V6 ATX 96K miles
Posts: 6,791 |
WTH are you guys talking about?
Posts: 7,100 |
Nothing relevant, Rawburt.
Have you made sure your belt, and tensioners are good, and tight?
Posts: 6,791 |
Yes, the belt would squeel upon battery light and voltage drop
Posts: 5,345 |
Originally posted by BatteryLight: Originally posted by Ray: Nothing relevant, Rawburt.
Rawburt, there's your answer. Either belt, tensioner or one of the pulleys are about to go. 1) Look at tensioner and see if it is at the end of the "notch". 2) Check belt. 3) Remove belt and rotate pulleys to see which is not rotating freely.
Posts: 6,791 |
No no no, I'm saying that the belt would do this. And it is not on my car.
Only time it squeels is on real fast shifts and at cruising speeds if I push in the clutch, rev it up and let it out (which makes sense).
