Well, it does sap horsepower if it locks up. My car didn't start and burned the belt when it did run due to the locked up pulley. I know that some people want to save weight by removing the A/C and they go out and buy a pulley bracket for it instead of what I did. And no, I haven't run my A/C for about a month now, it just got worn down. Also, if there is a pulley, there is going to be some sort of drag/strain on the crank. that is what the U/D pulley is for, to reduce the strain on the crankshaft. Same principles as this. reduce strain on the crankshaft by removing a pulley/ gain up to 4hp which isn't much at all, but the and then some means more than none.
