Is your air bag light flashing, and do you have cruise control working? If cruise is not working and you have airbag light, you have a clock spring problem. Unless you are comfortable with removing the airbag (after disconnecting your battery for 20 minutes), take it to the dealer. Actually, if you have a 2000 you are probably still under warranty.
Jim
98.5 SVT, Vortech SC, Bassani, Quaiffe, Clutchmasters Stg. 3, BAT Sport Springs/Konis, 17" Momo Arrows, Sparco Brace,BAT 22mm Sway Bar, PIAA fogs & headlights.
