Posts: 2,483 |
No smoothing function with the Zex kit, just on & off.
There have been the occasional failures of the TPS activation circuity of the box.
There isn't a way to test the solenoids by themselves (without opening up the box), you have to go through the control circuits. If your connections check out, call Zex and you should be able to send it to them to have the box fixed.
Frank McCoy aka Mod-deth aka Mid Life Crisis aka SVT Doood aka mcgainer is a SCAM ARTIST
Pre98 Zetec - Some Mods
Posts: 3,637 |
Confirmed it was the ground, i found a better postion and it works perfectly now.
Thanks guys.
230.2 WHP @ 6500
237.0 WTR @ 2250
much like your weiner.
Posts: 1,978 |
Against
Away from the throttle body for better atomization....
Alex
'99 SVT Contour
Posts: 3,637 |
thats what i thought, but wouldent it spray all over the MAF and IAC?
i mounted it pointing towards the UIM.
230.2 WHP @ 6500
237.0 WTR @ 2250
Posts: 1,978 |
I dont think the nitrous is going to get very far with all that air rushing at it....
I learned from Mark (that douche bag) so you'll have to wait for him to chime in.....
I do know when / if I spray ill have it pointing away from the TB, Dont want that stuff pooling.
Alex
'99 SVT Contour
Posts: 3,637 |
Originally posted by Pudmunkie: I dont think the nitrous is going to get very far with all that air rushing at it....
i mounted my nozzle RIGHT after the IAT so it has some way to move before it gets to the TB.
I thought the same thing about the better air disapation of the nitrous, but i didnt know if it would hit the MAF and cause an error.
230.2 WHP @ 6500
237.0 WTR @ 2250
Posts: 718 |
Originally posted by Pudmunkie: I do know when / if I spray ill have it pointing away from the TB, Dont want that stuff pooling.
I've sprayed the 125 shot many many times now and it has not puddled as of yet. I have my nozzle RIGHT AFTER the MAF sensor. I drilled and tapped the MAF housing itself for the nozzle.
1999 Cougar V6 MTX
SVT UIM/LIM/65mm TB, I/H/E, Fidanza/SPEC III/Torsen, Koni/GC's, 19" Icon wheels w/ Pirelli rubber, NX Wet Kit
Posts: 6,106 |
My nozzle WAS tapped into my T/B, pointing back, towards the MAF. Now, it's in a box, in my garage, awaiting pickup from Aaron.  Mark
2000 Black CSVT
Posts: 351 |
The zex systems are very picky about the ground. On Randy's car, we actually grounded it directly to the battery itself. Glad to hear you found the problem and fixed it.
Robert
Posts: 718 |
Originally posted by Y2KSVT: Now, it's in a box, in my garage, awaiting pickup from Aaron.
Mark
Mark i already have a nitrous sytem...i don't need yours!
1999 Cougar V6 MTX
