Posts: 718 |
I did the cut and weld on my 65mm TB using your SVT linkage Mark...
1999 Cougar V6 MTX
SVT UIM/LIM/65mm TB, I/H/E, Fidanza/SPEC III/Torsen, Koni/GC's, 19" Icon wheels w/ Pirelli rubber, NX Wet Kit
Posts: 6,106 |
Originally posted by 99cougar: I did the cut and weld on my 65mm TB using your SVT linkage Mark...
Haha, I was originally using that SVT linkage on my 65mm, until SOMEBODY just HAD to have my SVT throttle body!
Mark
2000 Black CSVT
Posts: 9,602 |
Originally posted by Y2KSVT: The SVT cable stop just BARELY fits into the 65mm T/B cam. Once you slide it in, you can't spin it, so the cable fits the groove that wraps around the cam. The Mustang cable stop must be a fraction smaller, so it will slide in and out easier.
Ever thought about taking a drill bit and enlarging the hole in the 65mm linkage?
Also I just used a rubber spacer at the accelerator pedal end to take up the extra cable slack.
Two very simple fixes.
I posted all of this years ago though...
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 1,746 |
Originally posted by DemonSVT: Originally posted by Y2KSVT: The SVT cable stop just BARELY fits into the 65mm T/B cam. Once you slide it in, you can't spin it, so the cable fits the groove that wraps around the cam. The Mustang cable stop must be a fraction smaller, so it will slide in and out easier.
He's BAAAAAaaaaaack
2000 Contour SVT
SF - #542 of 2150
Posts: 7,025 |
whoa, back from the dead greg? Where have you been?
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 4,141 |
Gone too long IMO, glad to see you stop in once in a while
Totaled 02/12/06
Born 3/24/99 Reborn 3/18/06
Posts: 9,602 |
I still read the occasional good thread. I usually just don't post.
2000 SVT #674
Posts: 6,106 |
I suppose I could have done that. But I didn't think the thin plastic walls could really take that.
Originally posted by DemonSVT: Also I just used a rubber spacer at the accelerator pedal end to take up the extra cable slack.
Then I killed 2 birds with 1 stone.
Originally posted by DemonSVT: I posted all of this years ago though...
I wanted to make you say it again.
Mark
2000 Black CSVT
