Posts: 27 |
u should really shift at 2500 to 3000 normal driving because a low rpm shift can really hurt a motor (driving). running a low rpm can damage ur motor out fast
Posts: 77 |
Originally posted by bscontour: u should really shift at 2500 to 3000 normal driving because a low rpm shift can really hurt a motor (driving). running a low rpm can damage ur motor out fast
How? Because when I need to accelerate fast I do, but if there is nobdy behind me, i accelerate at my own speed. What are the damaging affects?
Thanks.
Posts: 5,143 |
Originally posted by qokuh: Originally posted by bscontour: u should really shift at 2500 to 3000 normal driving because a low rpm shift can really hurt a motor (driving). running a low rpm can damage ur motor out fast
Thanks.
really there is none... The way I see it, if you drive an ATX and feather the gas pedal, and it shifts at 1900 RPM's then I see nothing wrong with doing it in a car with a stick. my dad always did that with his cars, and none of the cars he ever owned ever had serious mechanical difficulties, in fact, I think the worst thing to happen to one of his cars was a water pump. If there was very light traffic I would find myself shifting at 2000-2200 RPMS all of the time. Nothing wrong with it at all. I think what he means is it CAN be bad for the motor/trannie, if you are always horsing the gas pedal at low RPM's take for example, taking a low speed turn, leaving the car in 3rd, then punching the gas pedal... Thats a no no, if you are going to do that, mide as well downshift.
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
