Posts: 9,065 |
Originally posted by 99SVT: I've done this once before. It took me a month from start to finish. lol
But I know what I'm doing now. If it is really the trans and you really need it out asap I might be willing to help tomorrow night.
P.S. I pulled mine out the top with the motor, I've never pulled it out the bottom, I don't know what way you were planning on going.
Having pulled too many motors to remember, do the trans swap out the side. It really does take less time.
I get one day off a week...so ya.
Posts: 115 |
I have a hard time thinking it's the axles or carrier bearing since they can be spinning and the clutch pressed in and there is no noise. I have everything mostly unbolted so I just need to drop the subframe. Hopefully by lunch it'll be out. Thanks for all the advice, especially Judge - your advice allowed them to break loose, I just needed a bigger hammer.  If anybody still wants to stop by and admirer I have cold beer. Think of it as a mini-CEG meet.
Posts: 115 |
So I was waaaay off, I am an extremely slow worker as it turns out, everything was dropped and good until I tried to get the 2-3 transmission bolts loose in the front of the car. I am tempted to just pull it all from the top, I think that would be easier at this point.
I do have an offer for anybody semi-close with a down car. I will trade you my transmission, completely rebuilt with a diff of your choice for your transmission. Unfortunately I need it like now, which might be impossible but it doesn't hurt to ask.
Posts: 2,974 |
If you lived closer to me I would take you up on that offer.
Aaron
AKA NVS SVT
98.5 Silver/Blue SVT#4553
Yeah it's modded
98 T-Red/Blue SVT Contour Totaled 06/05/06
03 3L,VCN 2000,CAT Cams,MSDS Headers w/Y-Pipe,XCal2 and lots more
Posts: 1,165 |
Originally posted by vpogv: So I was waaaay off, I am an extremely slow worker as it turns out, everything was dropped and good until I tried to get the 2-3 transmission bolts loose in the front of the car. I am tempted to just pull it all from the top, I think that would be easier at this point.
Too bad this didn't happen like two weeks ago I had a stock rebuilt HMS trans just sitting in my garage. But I already sold it.
I live in Detroit, I couldn't give a **** how good my car is in the "twisties."
"I could use a hundred people who don't know there is such a word as impossible."
~Henry Ford
Posts: 115 |
Originally posted by 99SVT: Too bad this didn't happen like two weeks ago I had a stock rebuilt HMS trans just sitting in my garage. But I already sold it.
It's alright, a buddy has a trans but couldn't get it out in time.
Anyways, after resting part of last night I went at it tonight around 6 or so. At 10 tonight it came out. It took an hour to cut off one of the trans bolts, caused strain to every single coolant line and ripped a wire out of a sensor, but it came out.
TOB is fine, definitely the diff that is the issue. I'll have the trans shop take it apart tomorrow to check it all out.
Posts: 115 |
Differential was completely shreded, drivers side axle hub was more or less welded to the diff. Cheaper to get a new transmission than to get this one rebuilt. So to reiterate... if anybody has one sitting around ..
Posts: 5,143 |
Originally posted by vpogv: Differential was completely shreded, drivers side axle hub was more or less welded to the diff. Cheaper to get a new transmission than to get this one rebuilt. So to reiterate... if anybody has one sitting around ..
CTA motorsports has brand spankin' new MTX75's for only $900 Id jump on that.
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
