Posts: 67 |
WE ARE TRYING TO GET A LIST TOGETHER TO MAKE A FORMAL COMPLAIN TO FORD.
PLEASE CONTACT DUDE OR COORS with the following info: NAME & EMAIL ADDRESS you can be contacted at. YEAR OF CONTOUR PROBLEMS YOU HAD/HAVE With Motor/Ford Dealers. LOCATION(City, State)
Please give as much detail as you can.
Thanks, Brian
Brian D. Passaro -------------------- 1998 Contour SVT E0 Silver Frost #3734 of 6535 (Died 10/31/01 Reborn 02/03/02) Superchip(Removed)~Firestone Firehawks SZ50 215/45ZR17 on 17" Borbet Type T's~ASP Underdrive Pulley(Removed)~75mm Pro-Flow MAF(Removed)~Mobil One 5W-30 Tri-Synth~Resonator removed~Flowmaster DeltaFlow '40' series dual mufflers~KKM Air Filter Induction System(Removed"Lost at FORD Dealer")~2.5-inch custom cat-back exhaust system w/ reduced angle Y-joints~4-inch rolled chrome twin-tipped exhaust tips~Konig V-racing aluminum BTCC-inspired rear wing~Sylvania Blue headlamps
Posts: 2,025 |
NAME: Michael Amisano EMAIL ADDRESS: mamisano@optonline.net YEAR OF CONTOUR: 1998 E1 PROBLEMS YOU HAD/HAVE With Motor/Ford Dealers: Motor knock @ 42K miles. Replaced under extended warraty. LOCATION(City, State): Deer Park, NY
1998 SVT Contour E1, Black 2001 Honda SuperHawk VTR1000F "I bent my Wookie" www.mamisano.com
Posts: 645 |
Might as well put our info up here also Brian.
Chad Stroven jetski@mindless.com 1998.5 E1 Engine Blew 41K Engine replaced out of warranty but Ford split the cost with me $3250 out of pocket. Shamrock Ford, Dublin California
Chad ----------------- http://www.1dzine.com jetski@mindless.com 98.5 SVT ? KKM Tru Rev ? Glasspack instead of resonator ? Dyno Max Super Turbo Muffler w/Brospeed 3.5" Rolled tips ? Brembo/KVR Cross Drilled Cadnium Front Rotors and KVR Carbon Brake Pads ? Blown Engine Replaced @ 41K
Posts: 3,562 |
Brad Noon bnmotorsports@msn.com '99 SE Sport V6 MTX Spun rod bearing on number 5 cylinder at 47,000 $800 out of pocket, replaced short block myself with salvage yard 3 liter. I don't trust the area dealers with a hubcap 'cus they broke two of mine.
Brad Noon '99 SE MTX 3 point oh my God H.O. 179HP/178TQ BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!bnmotorsports@msn.com
Posts: 583 |
Eric Flecha Eric@RitterPenUSA.com 1999 contour svt engine blew #206 Galloway Ford, not under warranty Fort Myers, FL replace engine with 00 svt motor.. approx cost...3 grand
First I would like to congratulate my 2002 "The Perfect Storm" undefeated National Champions MIAMI HURRICANES*1999 Ford Contour SVT #206 00 SVT motor with Return fuel*Black-Tan*Cold Air Intake with 6" S&B Funnel Ram*Sho-shop off road y*Brullen Cat-Back 3.5" slant tips no res*Unorthodox racing crank pulley*Lotec Guage pod with Air/Fuel, Oil Pressure and Voltage*17" Image Tuners*215/40 Falken Ziex's* B/M Short Shifter*Nokya 9006/9005 80w/100w Xenon's*JSP wing*BNM White Faced HVAC*Custom svt emblemed rear*Bosch +4's*H/R springs*Euro Sidemarkers. Eric@ritterpenusa.com Centerforce Dual Friction Clutch and Fidanza Flywheel.
Posts: 67 |
Posts: 585 |
Steve Holland (sholland991@home.com) 1999 SVT Engine knocking, terminal engine failure (according to dealer) Took 3 months to get the engine from Ford. Crestwood, IL (now)
Posts: 446 |
Dave Bland spicyminiflea@yahoo.com 1998 E0 Lawrenceville, GA Engine locked up after 52k miles. Being replaced under warranty from dealership i bought from...not Ford
"this world has nothing to offer, come back soon." luti-kriss throwing myself an act of my own violation '98 Black SVT- 3949/6535 8k miles ticked away, Eibach springs, Koni Struts, SHOShop CAI, Ford 9mm racing wires, deleted res., lead foot...more to come. http://community.webshots.com/user/svtminiflea
Posts: 3,331 |
Antonio Wright Wright_Antonio@Hotmail.com 98 SVT Rod put a hole in the block.(I think) 45k Car is now totaled.
99' SVT 86' Toyota Pickup Beater - Tha Daily Driver
Posts: 3,419 |
jason.fullerton (at) verizon.net 1998 E0 SVT 86000 miles don't know what exactly was wrong, but a piston (forget which one) had LOTS of lateral movement in the cylinder (dealer - John Kennedy Ford, Conshohocken, PA - diagnosed as "bottom end knock" and once torn down I played with the piston myself - definitely terminal) Um, I did all the stuff in my sig to fix it.
Although, I don't think Ford is really gonna do squat. "Warranty is 36/36 and we've fixed every one that broke under warranty." Good luck.
