Posts: 669 |
So I know that I need a rt front bearing, GOt the nororius humming vibration sound that gets WAY worse on left hand tunrs or corners. For the past 6 months whenever i am stopped and proceed to accelerate I could hear this click noise in the front right side, it has gotten progressively worse to the point that now when I turn right I hear a BIG clunk and then when I straighten out I hear a smaller clunk on the right side (its a painful sounding noise). Any thoughts??
1999 Mystique Sport 2nd owner bought it in Sept 03 120000km 4 door, leather, loaded pics on cardomain, coatsy
Posts: 7,117 |
Sounds like maybe your struts are moving around a bit. Do you have a camber kit? 'Cause that is where I see this happening most often, with the camber kit.
Posts: 669 |
Nope no camber kit.. It almost feels like something is shifting out and then when I straighten up it clicks back in,. Frustrating as it won't do it unless I am driving, i.e. if I am stopped and turn the wheels it won't do it.. I am guessing it has something to do with the steering.. Could it be a control arm issue? Or ball joint? Or tie rod?
Posts: 669 |
Its like a Knocking sound when I turn a corner, and then it kocks again when I straighten up.. Anyone else?
Posts: 7,117 |
check that top nut on your strut/strut towers up front. Sounds just like the struts are bangin' around...
Posts: 5,600 |
If the struts were loose, it wouldnt just make one clunk when turned. They rattle (many clunks) over evey little bump. You can feel it in the floorboards. If its just one clunk, I doubt the struts are loose. However, they are easy enough to check, so you might as well.
Black 1998.5 CSVT
Posts: 669 |
No clunks or noises on bumps just on turning.
Posts: 15 |
When I broke the sway bar end-links on my taurus I had similar results, but that was on the rear of the car. I'm still not sure what was actually making the clunking sound, but when I replaced the end links it stopped.
I would pull the wheel off and inspect everything as well as you can. Try to get a look at as many bushings as you can to see if they're worn out. A good way to check bushings on control arms and end links is to just push and pull on them hard with your hands to see if you get any knocking or excessive movement.
'98 SVT Contour
(Bilstein Struts w/BAT Euro Spring kit.)
'95 SHO Taurus (R.I.P.)
Posts: 183 |
Check for a broken spring. My 4 cylinder did that.
Rich S
1998 SVT
1995 Contour 2.5 MTX 215K miles Son's car(dead and buried)
1997 Contour 2.0 ATX
1998 Contour 2.5 ATX
2004 Tauras Wagon 3.0 Duratec
