Posts: 50 |
I just did intake on the tour does anybody know what ur supposed to do with the long breather looking thing? i have a zetec.
-95 ford contour gl
CUSTOM exhaust
cold air intake
red brake calapers
new fog lights
Coming soon: lowering springs,shocks,struts,
rebuild on engine,17 inch rims,jrSupercharger,chiped
Posts: 979 |
Get a filter for it at autozone or a similar place, all you need to do is fab a holder for it to stick to the end of your breather tube. Or (if your fuel rail is small enough) connect it straight to your valve cover where the breather port is.
My ride(Cardomain link) :
'95 Contour 16V Zetec DOHC, Teal , ATX
Born on Sep. 4, 1995
86+ miles
*LEDs mods are on their way!*
Posts: 1,224 |
Yeah, I just used one of those "valvecover breathers" from Advanced Auto Parts. I think it is meant for a small block chevy. It looked like a tiny K&N filter.  I have a footlong or so hose running from the valvecover to my filter. I just have the hose ziptied onto the brake booster vacuum hose. Check it out... HTH, BP
Ben ---'96 Contour GL * Zetec ATX * Tan on Black steelies---
+++JRSC M62 Under Construction+++
My big-a$$ mod list.
Posts: 979 |
Thats the exact same thing I have with the exceptions of mine is blue and most of your mods.
86+ miles
Posts: 50 |
so ya'll are saying i juss plug that sensor into one of those little filters and im good?? do u have to have a breather??.....
-95 ford contour gl
CUSTOM exhaust
cold air intake
red brake calapers
new fog lights
Posts: 979 |
Originally posted by 1bdtour: so ya'll are saying i juss plug that sensor into one of those little filters and im good?? do u have to have a breather??.....
I hope there is no sensor. If you got rid of the airbox, you may need a breather for two reasons:
1) It helps filter escaping oil vapors into the atmosphere. 2) It looks good/cleaner.
IRC, I bought mine for $10 at advance auto parts. Its better than leaving the tube just lying their with no visible function.
86+ miles
Posts: 50 |
im not talkin bout the box im talkin bout the other big black lookin thing i think its a breather??
-95 ford contour gl
CUSTOM exhaust
cold air intake
red brake calapers
new fog lights
Posts: 1,224 |
Are you talking about the intake air temperature sensor?
Two wires going into it, with a orange tip?
Posts: 333 |
There are a few boxes on the stock intake for the Zetec.
The plenum on the top of the motor which I have been told that you need. The muffler going to the front of the motor that the Air Temp Sensor lies, the AFbox, and a muffler in the fender. Which one are you talking about?
Posts: 50 |
ok in the pic above its not there but it would go right next to the valve cover..it would be right on top of his plug wires
-95 ford contour gl
CUSTOM exhaust
cold air intake
red brake calapers
new fog lights
Posts: 21 |
Originally posted by 1bdtour: ok in the pic above its not there but it would go right next to the valve cover..it would be right on top of his plug wires
The obnoxious piece you're referring to is the intake resonator...it serves no real purpose, robs power and takes up space. In the intake system it is located between the plenum and MAF sensor, and forces incoming air down a dead end pipe. Ford did this to quiet engine noise, but it creates back pressure and reduces air velocity. My recommendation is to ditch the thing, just get a pipe 3" in diameter and connect it where it used to be. Don't forget to drill and thread a hole for your IAT (Idle Air Temperature) Sensor, or the ECU will get an inaccurate reading for the intake temp and incorrectly adjust the air/fuel ratio.
1995 Mercury Mystique MTX Zetec
Silver Grape
130+ K and still going strong
Posts: 50 |
k i did that i cut it off and kept the sensor where it was and covered the hole with a piece of steel but it seems like its robing hp with out it cuz when i left it on there and ran the car it seemed faster but when i took it off it seemed slower idk whats thats about thats y i was wondering.
-95 ford contour gl
CUSTOM exhaust
cold air intake
red brake calapers
new fog lights
Posts: 1,224 |
If the sensor isn't mounted in the pipe, it is measuring the air in your hot engine bay. This will pull timing, add fuel, and make your 'tour run like crap.
Get your IAT properly mounted in the intake pipe and it should all be fixed.
HTH, BP
Posts: 50 |
ok i left the sensor where it was in the stock place it was mounted and cute off the intake resonator then i put steel over the hole in the pipe so it shouldnt be gettin hot engine air
-95 ford contour gl
CUSTOM exhaust
cold air intake
red brake calapers
new fog lights
Posts: 536 |
if the steel plate is not sealed to the plastic it will leak unmetered air into the tubing making it run lean and hence running like crap.
97 contour gl mtx
front & rear upper strut tower braces
19mm bat sway bar
Koni struts w/GC knockoffs
Posts: 50 |
i need to juss buy more tubing and get rid of that lil peice to make sure no hot air is leakin into it
-95 ford contour gl
CUSTOM exhaust
cold air intake
red brake calapers
new fog lights
