Posts: 190 |
Well my car was missfiring about a month or so ago and then it stopped. It was running fine until last week. The code came up as a missfire on cylinder 6. So I replaced sparks plugs and it still missfires. I then replaced the wires and had the code checked again and it is still cylinder 6. I removed the coil pack and the terminals look fine. ANY ideas?
1998 Silver Frost CSVT
#4427 of 6535
Born January 15, 1998
AIM: cannondale828
Posts: 5,345 |
1996 V6 ATX 96K miles
Posts: 190 |
It sounds like it is the fuel injector because I forgot to mention that the car is also runnin lean. With me being new to all this, how hard and/or expensive is it to change an injector?
#4427 of 6535
AIM: cannondale828
Posts: 6,910 |
Originally posted by cannondalemtb: It sounds like it is the fuel injector because I forgot to mention that the car is also runnin lean. With me being new to all this, how hard and/or expensive is it to change an injector?
it isn't to bad, if you where planning to rebuild and clean the intake then you will ahve the perfect opurtunity to change the injectors.
I would double check the wiring to the injectors first, maybe it just came loose
- 95 Mystique LS - Zetec/5spd
Posts: 5,345 |
Posts: 1,593 |
Originally posted by cannondalemtb: Well my car was missfiring about a month or so ago and then it stopped. It was running fine until last week. The code came up as a missfire on cylinder 6. So I replaced sparks plugs and it still missfires. I then replaced the wires and had the code checked again and it is still cylinder 6. I removed the coil pack and the terminals look fine. ANY ideas?
Wow you have been busy since last night. Did you just replace the #6 wire?
If you are going to do a injector replacement, then we should take a whole Saturday and do the whole teardown/ rebuild IM cleaning!
MUST SELL - ECM computer new for a 98 V6 mtx + pats
Now trolling in a Red Nissan 4 x 4
Posts: 4,693 |
I would sure try some injector cleaner before replacing any injectors.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 190 |
Since the new plugs didn't work, I put my Ford Racing wires back on and returned the the new ones. I then started it up to drive to the gas station and it wasn't missfiring! But then halfway there, it started again. So I added injector cleaner when I filled my tank and now I am just waiting to see if it'll make a difference.
#4427 of 6535
AIM: cannondale828
Posts: 1,593 |
Originally posted by Big Jim: I would sure try some injector cleaner before replacing any injectors.
Jim,
Does injector cleaner really help? What kinds are good?
Posts: 190 |
Well, I just took her out again. It seems that it does not missfire when it is cool, but once it warms up, the missfire won't go away. Does that make any sense?
#4427 of 6535
AIM: cannondale828
