Posts: 718 |
Originally posted by TRicker: stage3= on/off switch. i drive toomuch i would put one in every couple months.
I have put 25,xxx miles on my Stage 3, and over 25 bottles of nitrous(some of it 100/125 shot) and my stage 3 is just fine. I think you should get the stage 3...traffic is not as bad as you imagine it is. And it holds/lasts great!
1999 Cougar V6 MTX
SVT UIM/LIM/65mm TB, I/H/E, Fidanza/SPEC III/Torsen, Koni/GC's, 19" Icon wheels w/ Pirelli rubber, NX Wet Kit
Posts: 1,860 |
Diamond pistons are made to order. All you need to do is ASK for stock compression. I sent them OEM pistons years ago. They have the specs.
I drove a stage III clutch for over a year as a daily driver. It's not that tough. Man up and drive it!
2001 Lincoln LS8
1994 Lexus GS300
Posts: 595 |
If you contact a sales rep from Spec directly, they can custom build you a clutch with organic on one side and ceramic on the other, whatever you want. You'll just pay more than if you got it from Cuervo.
Black 1998.5
3L Oval Port
Full HMS Transmission
Lots of other stuff
Ressurected 06/14/06
Posts: 6,106 |
anybody tried a centerforce?
This post right here, just goes to show that you have ZERO clue. First off, who told you that the stage 1 is too weak? Show me a post where someone has maxed it out. Then tell me how many people have gone through a stage 3. While you're at it, do a search for the stage 2 clutches, and see how many people recommend it.
Oh yeah, and Centerforce....
Mark
2000 Black CSVT
Posts: 21,197 |
Drove a Spec St. 3 and it wasn't bad at all. A LOT better than the Kevlar clutch I have.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 3,738 |
idk if spec clutches are basically the same through make/models, but the stg 2 i have on my jetta sucks.
~Andrew
2001 VW Jetta Wolfsburg Edition
20 valves of fury
Posts: 1,336 |
At first (first 2 hours), the SPEC Stage III felt like an on/off switch. Either I got used to it or broke it in within 3 hours, because now it's much more bearable and would work OK in city driving. Pedal pressure is only slightly harder than stock (which I think is on the soft side anyways). Only the "window" of engagement is closed smaller, thus making it feal more on/off. However, once you know where the window is open, you can easily modulate it.
Posts: 352 |
Stage 3 for a year plus, running 366ft/lbs. It's touchy, but quite livable once you get accustom to it. It's my daily driver, loads of traffic here in DC.
Dan G. and his Cougar
Forged internal (Diamond & Pauter) full 3L, "Monster" Kinger F/I cut & P&P, T3/4 60 trim .82A/R ADC turbo, SPEC Stage 3, Torsen, Greddy Profec-B SPEC II, Apex'i Timer, Lots of Gauges!
Used to have: 3.0L SVT hybrid
Posts: 533 |
i drove a spec III for a few miles (short trip) and the engagment was perfect. took me a few minutes to get used to it. after my short trip was over i wanted one soooo bad
koni kit - hpp rstb
camber/plates - cf (yikes!)
polyroll resistors - TCA's
WR headers/ypipe -TB hiflow cat
SFC's - XCal2
-dreaming of 3L-
Posts: 7,025 |
yeah, the engagement does take some getting used to. Its by no means hard to drive at all though. Imho, its no firmer than stock. Ive got about 8K on mine so far. Still holding up great. Its a daily driver too.
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
