Posts: 186 |
I was just looking at some TSBs and noticed that there is a new TSB #06-14-4, dated June 29, 2006 which states that Mercon V is a suitable replacement for Mercon fluid, including in the Contour CD4E. Here is a snippet of the TSB: Quote:
ISSUE: MERCON�® Automatic Transmission Fluid is being replaced by MERCON�® V as a service fluid.
ACTION: Beginning immediately all automatic transmission / transaxle applications requiring MERCON�® can now be serviced using MERCON�® V or MERCON�® Automatic Transmission Fluid or dual usage fluids labeled MERCON�® / MERCON�® V. After July 1, 2007, MERCON�® Automatic Transmission Fluid will no longer be manufactured, therefore, availability of this fluid will only continue for however long it takes to deplete what remains in inventory.
I thought this might interest some folks here, I haven't seen this particular TSB mentioned before. Here is a copy of the TSB in PDF format: http://cerberus.cowgod.org/tsb06-14-04.pdf
Tom
98 LX (Zetec/ATX)
Posts: 7,117 |
We ATX guys are now officially SCREWED!!! The manual specifically states, do not use Mercon V or damage may result. I dunno how long the Mercon will last, but I'm either gonna have to stockpile some, or buy new cars...
Posts: 5,143 |
Time for you guys to start finding a suitable alternative.
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Posts: 1,361 |
So what exactly is wrong with using Dextron III/Mercon fluids? There's no shortage of that, certainly.
'98 SVT Contour, in at least 639 pieces
4 Speed MTX...synchro and shift fork replacement in progress
Posts: 1,788 |
Originally posted by shotwell: So what exactly is wrong with using Dextron III/Mercon fluids? There's no shortage of that, certainly.
Nothing is "wrong" with it.
Ford finally decided that Merc V was a suitable alternative, so they are in the process of superceding the Mercon standard.
In any event, DEXRON III will still be around for awhile.
Steve
89 Taurus SHO - 246K miles
94 SHO ATX - 190K
