Page 4 of 4 1 2 3 4
Errr, if I have to make one more correction I'm going to go insane.
Well, the original M-17 bulb for the map lights is correct. The M-17 is a BA9S base.
Searching for my rear dome bulb, 12814, Polarg does show up with the M-17, but if I kept looking, I would of seen other sites show up with the 12814 as a BA15S base.
The BA9S is a 1" tall bulb while the BA15S is 1.4" tall bulb.
Easy way to put it, M-17 bulb DOES NOT work in place of the 12814, and Polarg is wrong! It will work for the map light as stated originally though.
The correct Polarg bulb for the Mystique rear dome is G-50. They do not have a bulb in the BA15S size in Super White. Only a different series and color is labeled "Visual White".
BA15S
BA9S
So that completes my list of bulbs minus the vanity bulbs. I still need to decide which ones I will go with for that. Again, anyone reading all this, it will be in a very simple FAQ soon. I want to buy mine, install them to test and be 100% sure everything works correctly and sizes are correct. I will take pictures and post all Polarg models to order.
Scratch that. Found the correct Hyper White series bulb for the rear dome. Don't need the Visual White bulb anymore.
M-25.
Page 4 of 4 1 2 3 4
