the reflector is leaking, obviously, it is taking on water and when you open the trunk it pours in ... you could take the reflector off and drill two small drain holes at the corner of the licence plate to let the water out before you open the trunk. otherwise take the reflector off and use some sealant to reseal the reflector to the trunk lid
