Posts: 351 |
Just checked it, it's fine. When I talked to the guy at Turbo-direct, he said that the symptoms sound like a blown turbo is a highly possible cause.
Robert
Posts: 351 |
After letting it cool off and the sun to drop down, I went out to the garage and took a closer look around. Looked for anywhere where oil is being sprayed onto something hot. I do not see any residue of such occurances. I went to double check the PCV, and realized that it is not there. Both valve cover lines are plumbed into a catch can which has a breather filter on top. This weekend is going to be a very extensive exploration of my car, checking everything and rewiring some of the crud under the dash. So while i have everything apart, i'll check the turbo for end/shaft play. I'm affraid to see how it is.
There are no leaks from any of the hoses or connections. Everything is clamped and threaded connections have teflon tape. It's begining to look more and more like the turbo.
Robert
Posts: 718 |
Originally posted by RobSVT-t: I went to double check the PCV, and realized that it is not there. Both valve cover lines are plumbed into a catch can which has a breather filter on top.
I'm pretty sure you HAVE TO have the PCV in order for the car to run. Are you sure u are not mistaking the valve cover vent lines for the PCV line? The PCV line goes into the UIM right under where the TB entrance is.
1999 Cougar V6 MTX
SVT UIM/LIM/65mm TB, I/H/E, Fidanza/SPEC III/Torsen, Koni/GC's, 19" Icon wheels w/ Pirelli rubber, NX Wet Kit
Posts: 351 |
Here are the best pictures i could get without removing the intercooler. Let me know if i do or not. I could be overlooking it.     Thanks for the help from everyone. Robert
Posts: 21,197 |
Sure looks like a PCV to me.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 718 |
Ya thats a PCV...why did you say you didn't have one?
1999 Cougar V6 MTX
Posts: 351 |
Guess i overlooked it. That was hard to get a picture of. And it being dark didn't help either. My bad.
Robert
Posts: 5,810 |
Originally posted by Keyser: Check your oil drain Robert. It's really difficult to get it completely verticle.
Good Point!
He says he has a catch can. Maybe thats full?
See My Mods
Posts: 351 |
Checked it and emptied what few drops were in there. It's getting worst as the days go on.
Robert
Posts: 5,810 |
Well then just to be safe, check compression while you are at it.
See My Mods
