Page 3 of 3 1 2 3
I'm sure most of you have already done this but try checking / cleaning the battery clamps. I had a bad hesitation under any acceleration in my 95 SE 5spd. I changed the battery b/c it was causing issues and it cleared up for a day or two then started in again.
Come to find out, I had a cracked battery clamp where it connects to the battery post.
Just another thought.
Check all your ground leads too. That'll cause a misfire.
I'll put holes in him!!
I had similar problems on my 98 SVT. I changed both bank upper O2 sensors due to CEL's. I then cleaned the IAC valve and the problem went away for a few weeks. When the bad idle/hesitation came back I bought a new IAC which seemed to cure the problem.
Do you notice any difference when the A/C is on?
98 Black Contour SVT, #2386 of 6535 How can you live without CEG?
Page 3 of 3 1 2 3
