I thought Bradness was referring to poly ONLY in the rear - that is certainly bad because of the design of the rear suspension. If you have stock rubber in the transverse control arms, the poly in the longitudinal arm will just make that arm have more effect on the position of thw wheel.
-Philip Maynard '95 Contour [71 STS | Track Whore] '97 Miata [71 ES | Boulevard Pimp] 2006 autocross results
