well im assuming that this is a common problems on contours because my girlfriends contour did the same thing. now my svt is doing it. the door handle seems to work when it want to. this is weird but its true. i can keep pulling on the door handle and the door will not open. ocasionally the door opens. what can i do to fix this?
well i should have thought about this a while ago before posting this, but pb blaster fixed the job. if anyone comes across this problem just spray some pb blaster or wd-40 on the latch and it will work in no time.
