Posts: 110 |
Is "carb" clean safe to use on a 4.6L with a plastic intake? Or is there a better product to use to clean my intake system. My car has 57200mi on it and it's never even had a tune up yet  . So I figured I would clean up the fuel system/intake tract before I put some new plugs in her. I've heard Ford uses a "special" coating on the throttle plates on these older mod blocks. Any useful hints or tricks would be cool. T.I.A Kyle
1997
Thunderbird LX
Clairion HU, sub and amp
In the works:
true duals, headers, cobra MAF
In the works: Mustang with a big block
Posts: 5,854 |
there was supposed to be a special coating on the throttle plates ou our cars too...if it was there, it didn't do crap. so don't worry about ruining it. I don' tknow about using carb cleaner on plastics though...i don't think it'll hurt, but why don't you grab a piece of scrap and test it out?
1999 Silver Frost SVT
#609 of 2760
Posts: 1,017 |
that stuff is pretty powerful, it'll strip paint off a UIM. I dunno how well plastic will hold up to it
1995 SE
2.5L V6/MTX
187k
Posts: 197 |
When I worked at a Ford dealership, we used the 3M brand stuff. It is safe for Teflon coated throttle bodies. Ironically, it is suposed to prevent the build up that accumulates anyways.
The ONLY 96 (engine) 3L
Build 'em fast. Spray 'em faster.
ricehatersclub.com
Posts: 1,241 |
Originally posted by platinum_drew: that stuff is pretty powerful, it'll strip paint off a UIM. I dunno how well plastic will hold up to it
It held up ok against a Sterilite plastic container.
Jake
96 T-Red SE V6
Posts: 110 |
Well, guess I'll go look at the bottles and see what they say. If I ruin my intake, it'll be an excuse to get a high flow BBK
1997
Thunderbird LX
In the works:
Posts: 5,143 |
Originally posted by CanadianContendr: Well, guess I'll go look at the bottles and see what they say. If I ruin my intake, it'll be an excuse to get a high flow BBK
I heard the plastic Intake manifolds on the 4.6L T-bird V8 had wicked problems, like there was a recal because the intake manifold itself would shatter. One of my friends has a 97 Loaded T-bird and he had that problem at like 47K miles.
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Posts: 110 |
That recall was for the thermostat housing/upper rad connect. They first made that piece out of cheap ABS plastic but recalled it to be replaced with a less problematic aluminum piece. I had the recall done before I imported the car into Canada.
1997
Thunderbird LX
In the works:
