Posts: 636 |
Originally posted by JEDsContour: Originally posted by elraido: Cause if it is a long block it included the lower compression pistions...and you really would like high octane gas for that....or you will get real nice knock.
I think you meant higher compression.
Yea I second that. Higher compression requires higher octane fuel.
-Mike
98 Contour SVT
Toreador Red #49 of 6535 Built on 3/25/97
WR Headers, Borla Cat-Back, Torsen T2 LSD, K&N Short Ram, S-AFC and Focus Shift Tower
85 Camaro
1969 358ci, 97 TA interior, 91 Z28 GrdEfx and Aero Wing 255rwhp
Posts: 2,116 |
Doh, I meant that. And 95's being I versus II is one of those tricky tinkering things I was talking about.
95 SE MTX
svt exhaust
intake
deer killer
Posts: 3,637 |
Originally posted by elraido: Doh, I meant that. And 95's being I versus II is one of those tricky tinkering things I was talking about.
+1
Your going to have fun unless you swap all the wiring and the ECU.
IIRC your going to need to replace EVERYTHING to get it to work with PATS.
230.2 WHP @ 6500
237.0 WTR @ 2250
much like your weiner.
Posts: 21,197 |
You'll be fine putting it in. The slightly higher compression and running 93 isn't going to effect anything. It just won't run as quick as an SVT since the timing will be slightly retarded from running 87. Just swap the manifolds and the vacuum seconaries to the engine.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 1,336 |
Save yourself a lot of greif and fix the car up as cheaply as possible and then sell it for a nice profit, which should be possible with it only costing you $500. Take the money you make and put it towards another cheap 96+ Contour and make THAT the basis for your project. Trust me, it will be a lot less of a hassel than trying to drop a 3L into a 95
Posts: 21,197 |
Originally posted by fastcougar: Trust me, it will be a lot less of a hassel than trying to drop a 3L into a 95
Actually easier in a 96 because you won't be throwing codes for OBD 2 all day. ![](/ubbthreads/images/graemlins/laugh.gif)
'95 Mystique
-'96 SE MTX 3L
Posts: 2,676 |
Originally posted by todras: You'll be fine putting it in. The slightly higher compression and running 93 isn't going to effect anything. It just won't run as quick as an SVT since the timing will be slightly retarded from running 87. Just swap the manifolds and the vacuum seconaries to the engine.
+1
I had a 99 engine in my 95. It just needed the vacuum assembly for the secondaries. It still would be cheaper to do the 3L than use an SVT block, but the whole computer setup would be the biggest problem.
Posts: 21,197 |
Originally posted by Wien_Sean:
+1
Stock computer works just fine.
-'96 SE MTX 3L
Posts: 2,676 |
Originally posted by todras: Originally posted by Wien_Sean:
+1
Right, nevermind I posted. I was thinking of something else.
Posts: 4,140 |
I put a '98 (non-SVT) engine in mine. There were no issues with the OBD at all.
