Page 2 of 3 1 2 3
#1606391 07/10/06 01:24 AM
Originally posted by JEDsContour:
Originally posted by elraido:
Cause if it is a long block it included the lower compression pistions...and you really would like high octane gas for that....or you will get real nice knock.
I think you meant higher compression.
Yea I second that. Higher compression requires higher octane fuel.
-Mike 98 Contour SVT Toreador Red #49 of 6535 Built on 3/25/97 WR Headers, Borla Cat-Back, Torsen T2 LSD, K&N Short Ram, S-AFC and Focus Shift Tower 85 Camaro 1969 358ci, 97 TA interior, 91 Z28 GrdEfx and Aero Wing 255rwhp
#1606392 07/10/06 02:37 AM
E
E
Doh, I meant that. And 95's being I versus II is one of those tricky tinkering things I was talking about.
95 SE MTX svt exhaust intake deer killer
#1606393 07/10/06 02:48 AM
+1
Your going to have fun unless you swap all the wiring and the ECU.
IIRC your going to need to replace EVERYTHING to get it to work with PATS.
Originally posted by MxRacer:
Originally posted by RawBurt:
much like your weiner.
#1606394 07/11/06 12:20 PM
You'll be fine putting it in. The slightly higher compression and running 93 isn't going to effect anything. It just won't run as quick as an SVT since the timing will be slightly retarded from running 87. Just swap the manifolds and the vacuum seconaries to the engine.
#1606395 07/11/06 02:07 PM
F
F
Save yourself a lot of greif and fix the car up as cheaply as possible and then sell it for a nice profit, which should be possible with it only costing you $500. Take the money you make and put it towards another cheap 96+ Contour and make THAT the basis for your project. Trust me, it will be a lot less of a hassel than trying to drop a 3L into a 95
#1606396 07/11/06 03:25 PM
Actually easier in a 96 because you won't be throwing codes for OBD 2 all day.
'95 Mystique
#1606397 07/11/06 03:28 PM
W
W
+1
I had a 99 engine in my 95. It just needed the vacuum assembly for the secondaries. It still would be cheaper to do the 3L than use an SVT block, but the whole computer setup would be the biggest problem.
1999 Contour SE Duratec ATX My feet and the Stra�Ÿenbahn http://www.tempo-topaz-performance.com/topazsho/ the coolest Topaz ever! To bad it's not mine
#1606398 07/11/06 03:51 PM
Originally posted by Wien_Sean:
+1
Stock computer works just fine.
#1606399 07/11/06 06:54 PM
W
W
+1
Right, nevermind I posted. I was thinking of something else.
#1606400 07/11/06 07:07 PM
I put a '98 (non-SVT) engine in mine. There were no issues with the OBD at all.
-Philip Maynard '95 Contour [71 STS | Track Whore] '97 Miata [71 ES | Boulevard Pimp] 2006 autocross results
Page 2 of 3 1 2 3
