Posts: 1,834 |
Hey guys, got a question i feel I should know the answer to but don't... but first some backstory. I recently purchased a 95 Mystique with the intention of my dad driving it. The car didn't run but was in pretty nice shape and only cost $500. It's been in at the ford dealer where i work and it now runs, but the tech is thinking it has either a burnt valve or a sticking valve in the rear head. I'm looking for the most bang for my buck here. I figure to r&r the rear head and redo the timing and everything has got to be 10 hours labor or so (I haven't looked it up, just a guess) not to mention the cost of getting whatever work done to the head I'll need.
Now, the question. I saw in the classifieds a 99 SVT block and heads for sale in Canada with about 64K miles. I know the 95's are OBD1, but if I use all the standard electronics would the 99 engine run on OBD1 without any real issues? One thing I'm concerned about with this idea is the injectors and if the 19# injectors would/could work from the stock computer or if chips or anything are available for the OBD1 ecu.
My other two options I'm considering are just some SVT heads or the one I least want to go with is just having the stock head redone. Anyway, thoughts, knowledge and even opinions on the subject would be appreciated. I'll check back in about a week when I get back to civilization.
Shawn Clone
Jezabel- 1999 SE Sport V6 MTX- Severly wounded, comatose
Silver frost/Black Exterior-Midnight Blue Interior
The Firecracker- 1995 Mystique LS V6 MTX stock and backfiring like a rifle shot
I have 3 loves, my God, Brittany, and my Car.
Posts: 937 |
SVT block and heads? You are basically describing a long block, right? No problem, bolt on all the 95 parts, LIM and UIM. There is absolutely no mechanical reason at all to run 19# injectors.
99 Tropic Green SVT, Tan Leather, 20K miles, "Nice Twin" (factory stock).
99 Tropic Green SVT, Tan Leather, 28K miles, "Evil Twin" (Turbo AER 3L and more in progress)
96 Red LX, Opal Grey Leather 2.5L, ATX, 22K miles
Posts: 5,143 |
Originally posted by JEDsContour: SVT block and heads? You are basically describing a long block, right? No problem, bolt on all the 95 parts, LIM and UIM. There is absolutely no mechanical reason at all to run 19# injectors.
It obviously would work... But I think about this and I personally think you should go 3L. I mean, yeah how cool would that be? a 95 stique with an SVT motor... But that means you have to run high octane gas, with is $$$ Or you could go with a 3L for about the same price, with the same amount of miles, get a better motor that puts out more power, gets better gas mileage, and will run on regular gas if properly tuned.
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Posts: 6,910 |
Originally posted by AliasJerkââ??¢: Originally posted by JEDsContour: SVT block and heads? You are basically describing a long block, right? No problem, bolt on all the 95 parts, LIM and UIM. There is absolutely no mechanical reason at all to run 19# injectors.
why would a SVT engine in a 95 need premium fuel? To make it work you would have to use all of the sensors, etc from the 95 ... that includes the pcm, which is already tuned for regular not premium
- 95 Mystique LS - Zetec/5spd
Posts: 2,116 |
Originally posted by BrApple-SeVT: Originally posted by AliasJerkââ??¢: Originally posted by JEDsContour: SVT block and heads? You are basically describing a long block, right? No problem, bolt on all the 95 parts, LIM and UIM. There is absolutely no mechanical reason at all to run 19# injectors.
Cause if it is a long block it included the lower compression pistions...and you really would like high octane gas for that....or you will get real nice knock.
95 SE MTX
svt exhaust
intake
deer killer
Posts: 5,143 |
Originally posted by elraido: Originally posted by BrApple-SeVT: Originally posted by AliasJerkââ??¢: Originally posted by JEDsContour: SVT block and heads? You are basically describing a long block, right? No problem, bolt on all the 95 parts, LIM and UIM. There is absolutely no mechanical reason at all to run 19# injectors.
exactly, Premium gas required doesnt just mean that the computer is tuned for it. Its both software and hardware.
TEIN H.Tech Springs
Posts: 2,116 |
I keep thinking of putting a 3.0L in my car when the engine desides to die, but there are so many little different "tweeking" things that need to go on, I am not sure it would be cost effective as getting a new car.
95 SE MTX
svt exhaust
intake
deer killer
Posts: 3,637 |
i hope you guys realize that 95's are OBDI and 96+ are OBD II
230.2 WHP @ 6500
237.0 WTR @ 2250
much like your weiner.
Posts: 937 |
Originally posted by elraido: Cause if it is a long block it included the lower compression pistions...and you really would like high octane gas for that....or you will get real nice knock.
I think you meant higher compression.
Posts: 937 |
Originally posted by Tourige: i hope you guys realize that 95's are OBDI and 96+ are OBD II
Yes, I realize that. So what?
