who said this was a competition
never read the how-to so I don't know what it says
what do you call the alternator, ps pump and ac compressor, accesories and they are driven by a belt ... so put two and two together and an accessory belt is the same as a serpentine belt ...
the splash shield I was refering to are the removable shields in the wheel well, I called it a splash shield becasue the cars originally didn't have those and water would splash into the belt area and cause the belt to slip, therfor causing lose of ps, ac, alternator until the belt stopped slipping ...
often when you go to remove the tie rod end the tie rod will come free before you can get the nut off. you do know the tie rod end has a tapered fitting, so when you tighten teh nut down it basically locks itself in. now if you jus thit it with air tools you might have issues and mess the thread up. So to keep the pin portion of the tie rob end from comming free of the taper and spinning freely thus not allowing you to remove the nut the end has been cut for a 7mm allen wrench, iirc the size corretly, this will keep the thread from turning and allow one to work the nut off it does become a problem ...
asshat, lol thats rich ...
