Page 30 of 54 1 2 28 29 30 31 32 53 54
My car will not have the front bumper fixed.. nor will the wheels be refinished.. so dont pick on her too bad.
1998.5 Diamond White Pearl SVT (#4725) custom exhaust/intake k&N/mod'ed y-pipe slotted rotors/greenstuff pads/SS lines cougar trans/FSVT shift tower/Torsen 16lb. flywheel 18" Velox VX-8's with some rubba bands
Steeda. Offline OP
Captain Impound Boy
Captain Impound Boy
LOL, after my first Alt went out on the SHO my battery light came on but stayed on constantly.
It was a real easy fix though. would you like to know what i did?
Let me guess... You unhooked the battery light
Originally posted by BatteryLight:
I thought I remember you saying somewhere that after you put in the new alternator that you were still getting a battery light.
Originally posted by BiggityBon:
just don't take it near that!!! you can still drive comfortably under 3500 and have fun!!!
Yes I know, but I can not have fun while shifting at 3500 RPM. Eeeek, im gonna have to keep it cool on the high way, 70 mph = about 3000 RPM, IIRC.
Jeez, I thought OD ran higher then that on the duratec... My zetec did about 3100 RPMS while going 75 IIRC. I know the Duratec final drive is much higher then that... unless you had a zetec final drive installed when you had your trannie built...
No
Steeda. Offline OP
Captain Impound Boy
Captain Impound Boy
I had a bad cell in a battery, so i put a peice of tape over the light behind the dash
you're correct, i did. after the new alternator was in, he revved it up past 6000RPM and it flickered a couple times. since then, i have not taken it anywhere near that!
*~Bonnie~* 2000 CSVT, Amazon Green, built 2/?/00 135K and counting!!!!
Originally posted by Kremithefrog:
CSVT, because like an orphan, someone has to take care of them.
G-H-E-T-T-O
Steeda. Offline OP
Captain Impound Boy
Captain Impound Boy
Ill go get my old car and you can tell me if you can tell.
The SHO wasn't a fan of the Redtop for some reason
is rawbutt going to turn every post into a bitchfest about his car?
Moderated by  WorldTour_dup1
