Originally posted by Tony2005:
Originally posted by GeoPappas:
... Like I said, the RPMs are actually dropping by about 500 when this happens. The weird thing is that it seems to only happen when I am driving up a steep hill. Any thoughts on that?
I wonder if it is the air and fuel filter.
If it was the air and/or fuel filter, then I would think that the "jerking" would happen at other times as well (besides when climbing a hill).
Besides that, the air filter is relatively new (since it was changed a few months ago), and the fuel filter was replaced last year.
