#1602054 07/01/06 12:00 AM
E
E
i was out driving last weekend and about 3 blocks from my house the car died, it just stalled right out. Everyone told me fuel pump...fule pump. So i went out and paid $200 for a new pump.Screwed around for 2 hours to put it in. THE CAR STILL WONT TURN OVER!!!! I checked the fuse and relay and there good.With the tank in the pump i cant hear it runing or not. I'm stumped i'm abosultly stumped!! I'm ready to throw a match at the thing and blow it to bits
1995 MYSTIQUE 2.0L -16" SVT wheels -Custom intake with HKS filter -audiobahn/pioneer stereo -Graphite grey met -Netherlands Plates
#1602055 07/01/06 12:27 AM
Sure it's not the fuel pump relay? Will it crank over with the starter, but will not run?
JD a.k.a Fingers "Don't Panic" '98 Contour GL 2.0L VCT ATX 88k '98 Contour LX 2.5L MTX 120k Street racing can kill just less of a chance with a 2.0
#1602056 07/01/06 02:39 AM
Calm down man... everyone runs into these problems. Does the fuel pump prime when you turn the key to the on position just before you start it?!?! Did your fuel pump shut off switch by the drivers feet somehow get tripped??? We will help you out, but we need exact details of everything you have checked. It is rare, but possible that your fuel filter is completely clogged!!!
-Reebs-
For Sale - 96 Tour Sport 2.5L MTX with SVT Exhaust, pre 98 trunklid with newer Contour Sport spoiler instead of lip spoiler, newer Contour sport rims. Newer paint job. Brand new floor mats. Rust Free! PM me for details and pics.
#1602057 07/01/06 06:22 PM
E
E
-Fuel pump replaced
-ignition fuse replaced (some moron took one of the maxi fuses and ran a wire thew it to jump it)
-unhooked the bat and re hooked it up (to see if it would reset something)
- fuel pump fuse good
-relay tested and good
-mass air flow, air temp and idle air cleaned
-Filter i have a new one but i need to get the car up to change it
I was reading something in the hanes manual about a fail-safe mode (limp-home mode) could it be that??? it said i have to get it on a comp to fix it
