Posts: 1,359 |
My SVT has been garaged for a while and I want to run some fuel injector cleaner through it. In the past I have used that B-12 (I think the manufacturer was Berryman's if I remember correctly). Am I best off using that or are there some other cleaners out there that are better?
98' Contour SVT
#607 of 6535
05' Mazda 6s
Audio/Visual enthusiast because it's one of the many things I went through 4 years of hell for
Posts: 99 |
That or Seafoam are GREAT products. I use Seafoam in my Cougar.
Posts: 980 |
The Berryman's is my preference. Big Jim will likely chime in here later with his. Personally, whatever it is that he uses is slighting better (IMO) but the Berryman's is much cheaper where I live...
2000 Mystique LS
Duratec 2.5L MTX
Posts: 21,653 |
I use whatever I can take from work. Right now, we have decent stuff, I think it's called 44K made by BG.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 3,867 |
Originally posted by Kremithefrog: I use whatever I can take from work. Right now, we have decent stuff, I think it's called 44K made by BG.
BG 44K is good stuff, but a little pricey if you don't have an "in."
Otherwise I use the Chevron Techron.
Function before fashion.
'96 Contour SE
Posts: 2,116 |
The BEST stuff that I have ever had put in my car was the valvoline foam injector clearner stuff. It is hooked up to the fuel line directly and then you turn off the fuel pump and let it do it's work. It is like $40-$50...and another $40 or so if you have a shop do it, but it is greaaaat stuff. MUCH better then any of the stuff you put in the tank.
95 SE MTX
svt exhaust
intake
deer killer
Posts: 4,693 |
Originally posted by Tisby: The Berryman's is my preference. Big Jim will likely chime in here later with his. Personally, whatever it is that he uses is slighting better (IMO) but the Berryman's is much cheaper where I live...
As long as you adked for my input, I like BG 44K, Techron, and Red Line SI-1. I have heard good things about Valvoline Synpower as well. I like Berryman's for the vacuum suck intake cleaning.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 439 |
Gumout with REGANE is also good stuff. I started getting CELs with both Valvoline and Chevron fuel system cleaners (they went away with a fresh tank of gas), but gumout gets the job done really well with no CELs. Just get the stuff in a a CLEAR bottle with yellow liquid and it says REGANE in small letters, the other gumout stuff is much less effective.
Ohsigmachi '96 GL MTX Zetec
--I don't won't to hurt you, but it's still on my list of things to do.--
View project Slippery Slope
Posts: 4,639 |
Hugo AIM:omegazodiac
Posts: 5,975 |
Techron with every oil change (5k) and Berryman's thru-the-tube every 15k.
