Posts: 1,609 |
YA YA YA I know I have been gone for awhile but... I just replaced my thermo and now my high speed fan will not turn off when the car is running. I will start the car, fan will be off, will warm up and wamo the high speed fan will stay on even in 50�º weather like this morning (earlyyyy) Its been like this for a few days now. Also, I got the stock thermo, the engine temp gauge reads on the O of normal, and the A/C is off. Any suggestions?
1998.5 SVT contour #5979 3L
1995 Mercury Mystique 2.5L auto, all ghetto fo sho
Posts: 7,100 |
Link Perhaps that sounds familiar?
'99 CSVT - Silver #222/276
Posts: 1,609 |
Kinda, cept mine does not turn off at all. I am going to make a run into town and then ill start pulling stuff from it. Ill reset the comp first before I go and see what that does
Posts: 1,609 |
Pulled fuse 4 and 11 waited a min then went into town (about 15 mins in 80�º weather) no high speed fan. Come home, still no high speed fan, car ran at the O in normal again. Pull in the garage, turn on the A/C no high speed fan but the low speed is on. Turned off A/C high speed fan turns on. Shut the car off. Restart the car, high speed fan comes on, turn A/C on high speed still on, turn off A/C still on. Shut the car off. Restart car once again, no high speed fan, turn on A/C again no high speed fan (leave A/C on for 20 sec), turn A/C off still no high speed fan.
Boy am I confused.
Posts: 1,456 |
My cooling fans operate like this:
Cold engine, no a/c NO cooling fan
Cold engine, a/c on, Low fan speed
Engine Temperature at M on scale a while will trigger Low speed if a/c is off
Temp at M and A/C on may trigger high speed fan
Hot weather, 85 degrees, hot motor and A/C on will cause high fan to cycle alternately with low fan, pressure in a/c varies, high pressure=high fan
Might run on steady high in hot day slow traffic (I have not seen this)
I think your system is OK!
