Posts: 21,197 |
Just make sure it stays on the 2.5 just as it came off. This is because you still use all the 2.5 timing components.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 587 |
I am swapping over my cams from my SVT onto my 3.0L and I can�t remember if I saw a threat about telling the difference between Taurus cams and the SVT cams. I thought I remembered the SVT cams having a green stripe on them.
I took the part number from my cam F73E-6A269-BA and checked the web without any results. I don�t know what I am worried about, I just thought for a second I could have been screwed and the seller to never think I would go in there to notice. I just like reassurance
3L process done
Posts: 587 |
3L process done
Posts: 114 |
Nice pics! This will definetly help me out!
Sal
SHOCal Advisor / Midwest Duratec Co-Owner
[img]http://www.supermotors.org/getfile/260278/original/CrackerBarrel.jpg[/img]
Posts: 587 |
3L process done
Posts: 718 |
I'm pretty sure that is the knock sensor.
1999 Cougar V6 MTX
SVT UIM/LIM/65mm TB, I/H/E, Fidanza/SPEC III/Torsen, Koni/GC's, 19" Icon wheels w/ Pirelli rubber, NX Wet Kit
Posts: 587 |
Originally posted by 99cougar: I'm pretty sure that is the knock sensor.
Any idea of how the SVT Knock sensor fits on the Taurus Block?
3L process done
"Absolut Rara."
"Absolut Rara."
Posts: 3,223 |
Originally posted by bradSVT: Originally posted by 99cougar: I'm pretty sure that is the knock sensor.
Either splice the Taurus sensor into the 2.5L harness, or drill and tap the block for the 2,5L sensor. todras prefers to drill and tap, while most other prefer to splice in the connector to use the 3L sensor.
Posts: 1,746 |
That's what I will be doing.
2000 Contour SVT
SF - #542 of 2150
Posts: 227 |
are you not rebuilding the 3L engine? all that and your putting used back in? i do not believe in doing that. oh well, to each his own, and good luck
1998 CSVT
NX stage 1 ford EFI kit
MSD dis-4
B&M short throw
K&N short ram intake
Fsvt Euro 17's
Trubendz 2.5" exhaust
Spec stage 3
249.9 HP 258.2 TRQ clutch slipping the whole time
