Page 11 of 28 1 2 9 10 11 12 13 27 28
F
Smurfette
Smurfette
F
aww, she's just a stubborn old lady, that's all.
Like my GL. It's hard not getting pissed at her for being SO DAMN HARD TO WORK ON - BLOODY OLD STUBBORN BISNITCH!
I think turning this into a mod meet might be pretty fun.
When is the last time we all got together for a large mod meet?
DMD?
jd2-98s Offline OP
If worst came to worse, I have an extra tour you can drive back home
I have a 4hp compressor and airtools, and everything needed to do the job, Elky should bring that jack so I can add it to the tools, I mean check it out. Hey we could even make a how 2 video lol
Too bad bradness doesn't have my subframe done, we could be doing some serious work hehe
The only problem I ever have (and maybe because it was a 4 bolt type arm) is getting that arm down enough to get it back into the knuckle. IIRC you do have to pop the ball and the tie, the press the axle out the hub.
JD a.k.a Fingers "Don't Panic" '98 Contour GL 2.0L VCT ATX 88k '98 Contour LX 2.5L MTX 120k Street racing can kill just less of a chance with a 2.0
i got my csvt working, shes good to go. i got the day off so me and my girl should be able to meet up.. any CT people want to meet up and cruz up there together, let's figure someplace out to meet...
also, umm.. directions would be cool. im all set with getting to the jamestown bridge and all, just need to know where to go after that.
http://www.cardomain.com/ride/2424902 1998.5 Contour svt #5447 of 6535 B&M short Throw Shifter KKM intake borla catback (truebendz)
E
E
haha..no jack for you!!
a cool trick for lowering the LCA enough to get the ball joint in:
take a short piece of chain, at least 18", wrap it around the LCA connect the ends with a nut and bolt.
then take a long piece of pipe, feed it through the chain under the LCA and rest the end under the subframe.
now you have a long lever that pulls down on the LCA.
i did my drivers side axle with brand new 4-bolt LCAs and got it down far enough just using a prybar.
don't forget to loosen the pinch bolt and slide the hub up on the strut, that will create extra clearence to get the ball joint apart
sure let me know, I am not sure where I will be leaving from through, depends which car I take and where it is, might leave from Enfield or Monroe ...
F
Smurfette
Smurfette
F
alright
So to get there for 1 pm, Mike and I will need to leave at 10 am.
Dan from Derry, NH Mike and I can meet you at 10:15 at the weigh station on I-93 south (a bit after exit 4, but before exit 3, in Windham).
Elky & Haroon? We can meet you at 10:45 at the Hannaford/Bally's plaza in Lowell (close to Elky's house)
From there we plan on taking 495 to 95S then down route 24S and into Newport.
E
E
works for me.
H
H
ahhh...this is coming up so quickly and I haven't finished half the things I wanted to Stupid humidity being above 60% ALL the time
LAME excuse..lol
Moderated by  baco99, frenchblueC2_dup1
