Posts: 23 |
Oil is a highly engineered product, and using oil additives really messes with the careful chemistry of engine oil. If you use a high quality full synthetic oil, it is even more critical not to mess with it. Engine oil has all the additives it needs put in already. Fuel additives are a different issue, since fuel isn't as carefully engineered as engine oil and other lubricants are. If your engine oil isn't engineered well, for god sakes stop using that brand.
Posts: 439 |
your, right oil is extremely stringently engineered product, but to what end? Engine longevity or fuel mileage and emmisions? It's a fact that newer API SM rated oils have less anti-wear and anti-friction additives (namely ZDDP and Moly). Oil additives like Valoline Synpower oil treatment, SX-up, Lube Control, and Auto-Rx have also been very stringently manufactured for cars that need more of these additives that are no longer found in newer oils (like pre-98 contours that you buy used that may not have had the best maintenence records in the past).
Ohsigmachi '96 GL MTX Zetec
--I don't won't to hurt you, but it's still on my list of things to do.--
View project Slippery Slope
CEG road warrior
CEG road warrior
Posts: 17,248 |
I had 140k when my car was sold, driven hard everyday, and installed a S/C at 120k. Never once used an oil additive. Just Mobil 1 every 3-5k. BTW every Zetec I have every heard had the tick.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 439 |
Hector, I'll wager that your tour lived most of it's life on API SL rated oil. SM has only been around since about the Hurricane Katrina timeframe. It has a lot less of the traditional oil additive package that was used for most of the Contours model life and recently.
My car has 86,000 miles and no tick.
Posts: 23 |
If you use a high quality synthetic oil, there is no reason to add extra stuff to oil. Auto-Rx is an additive meant for claening not for running all the time. Personly I haevn't used Auto-Rx, since I run full synthetic oil in all cars I own.
Posts: 498 |
tick on pre 98's don't start untill around 115,000 miles.
96' ATX Zetec- stock
96' ATX Zetec- Modded
Kenwood KDC-319
5.75"-2 MTX 12's
Roady XT
Custom door panels
Mystique Cluster/oil pressure
Getting repainted(in primer)
Pre98 Lip
SE skirts
Mystique front lip
dingless
badgeless
Posts: 439 |
Originally posted by iso50: If you use a high quality synthetic oil, there is no reason to add extra stuff to oil. Auto-Rx is an additive meant for claening not for running all the time. Personly I haevn't used Auto-Rx, since I run full synthetic oil in all cars I own.
Actually Auto-Rx recomends running a "maintenence dose" all the time.
Posts: 23 |
Originally posted by ohsigmachi: Originally posted by iso50: If you use a high quality synthetic oil, there is no reason to add extra stuff to oil. Auto-Rx is an additive meant for claening not for running all the time. Personly I haevn't used Auto-Rx, since I run full synthetic oil in all cars I own.
Avoid it, and just run a good synthetic oil. I have not needed to use Auto-Rx, since my synthetic oil keeps the engine clean.
