I suspect your waterpump may have a piece broken off the impeller. Thermostats are known to stick closed as well, causing overheating. Let us know what you find was the problem.
Originally posted by FavoriteMystaque: I suspect your waterpump may have a piece broken off the impeller. Thermostats are known to stick closed as well, causing overheating. Let us know what you find was the problem.
Yes I will def. keep you guys informed.I suspected the waterpump impeller first but after reading the "common problems" on the main site i'm now thinking it is my t-stat,because my heater blows hot air when overheating not cold air.Anyways i'll keep you guys infomed.
