Page 4 of 5 1 2 3 4 5
Originally posted by Captain Bart:
The more you mod your SVT, the less return you get on your money.
It has nothing to do with that. I haven't transfered any of my mods to it as of yet. It's just the problem I'm having with the car that makes me want it gone.
Aaron
which kind of problem
1998.5 Toreador Red/Midnight Blue Contour SVT - #5912/6535 - DOB - 05/11/1998 - RU-3530/CTA Intake Pipe MSDS Heaser/Y-Pipe Magnaflow #10435 9mm Ford racing SPEC Stage one/Spec Alum. Flywheel HERE
CEL. I didn't know the light was on until after I had bought the car (light was covered over, I only noticed it because I was in the passenger seat). Took it to get looked at because it had a problem with emisissions and got quoted $1600 plus taxes . So the car is just a driveway ornament until I can get money to fix it. Should be good to go very soon tho .
Aaron
im so happy to never have to pass emission test
Yeah rub it in some more .
Aaron
Wow Aaron you have nothing but bad luck with your SVTs!
I feel bad that so much crap always happens..
What do you have to fix/change for $1600??
Martin
98 Contour V6 MTX CTA Exhaust/CTA Intake/MSDS Y-pipe/Bat Handling Kit/Predator Alarm/Spec1 Clutch Kit/SVT Flywheel/G Assurances Fix your car yourself "It's not a UFO." Todras
Martin
Yep I have been having bad luck, hopefully that changes.
The dealership wrote down o2 sensor at the back of engine, MAF (readings were low), replace UIM/LIM gaskets (Vaccum leak they said), clean UIM,Check for clogged cat, Motor vac service.
Aaron
Minus the Motorvac service.. most people here can help you do those things.. heck I changed the 02 sensors myself and the cleaned UIM and changed the gaskets.. I'm sure if we have a mechanic meet we can all help you out
My biggest fear is doing all that work then it still doesn't pass e-test, I will be one very pissed off person. I like the meet idea I would have to say it will have to be at my house due to the fact my car has no plates and the alternator went bye bye .
Aaron
in my case i need to pull out the clutch/tranny tuesday to see what going on... my car sitting at my father's garage since about 5week now... but since i got 10$ hour labor... i have no other choice then waiting
so i know how you feel...
Moderated by  Gerald_dup1, mbb41_dup1
