Posts: 2,974 |
Originally posted by Captain Bart: The more you mod your SVT, the less return you get on your money.
It has nothing to do with that. I haven't transfered any of my mods to it as of yet. It's just the problem I'm having with the car that makes me want it gone.
Aaron
AKA NVS SVT
98.5 Silver/Blue SVT#4553
Yeah it's modded
98 T-Red/Blue SVT Contour Totaled 06/05/06
03 3L,VCN 2000,CAT Cams,MSDS Headers w/Y-Pipe,XCal2 and lots more
Posts: 785 |
1998.5 Toreador Red/Midnight Blue Contour SVT - #5912/6535 - DOB - 05/11/1998 -
RU-3530/CTA Intake Pipe
MSDS Heaser/Y-Pipe
Magnaflow #10435
9mm Ford racing
SPEC Stage one/Spec Alum. Flywheel
HERE
Posts: 2,974 |
CEL. I didn't know the light was on until after I had bought the car (light was covered over, I only noticed it because I was in the passenger seat). Took it to get looked at because it had a problem with emisissions and got quoted $1600 plus taxes  . So the car is just a driveway ornament until I can get money to fix it. Should be good to go very soon tho  . Aaron
AKA NVS SVT
Yeah it's modded
Posts: 785 |
im so happy to never have to pass emission test
MSDS Heaser/Y-Pipe
Magnaflow #10435
9mm Ford racing
HERE
Posts: 2,974 |
Originally posted by SVT3Rivieres: im so happy to never have to pass emission test
Yeah rub it in some more .
Aaron
AKA NVS SVT
Yeah it's modded
Posts: 234 |
Wow Aaron you have nothing but bad luck with your SVTs! I feel bad that so much crap always happens..
What do you have to fix/change for $1600??
Martin
98 Contour V6 MTX
CTA Exhaust/CTA Intake/MSDS Y-pipe/Bat Handling Kit/Predator Alarm/Spec1 Clutch Kit/SVT Flywheel/G Assurances
Fix your car yourself "It's not a UFO." Todras
Posts: 2,974 |
Originally posted by The1stAcekiller: Wow Aaron you have nothing but bad luck with your SVTs! I feel bad that so much crap always happens..
Martin
Yep I have been having bad luck, hopefully that changes.
The dealership wrote down o2 sensor at the back of engine, MAF (readings were low), replace UIM/LIM gaskets (Vaccum leak they said), clean UIM,Check for clogged cat, Motor vac service.
Aaron
AKA NVS SVT
Yeah it's modded
Posts: 234 |
Minus the Motorvac service.. most people here can help you do those things.. heck I changed the 02 sensors myself and the cleaned UIM and changed the gaskets.. I'm sure if we have a mechanic meet we can all help you out
98 Contour V6 MTX
Posts: 2,974 |
My biggest fear is doing all that work then it still doesn't pass e-test, I will be one very pissed off person. I like the meet idea I would have to say it will have to be at my house due to the fact my car has no plates and the alternator went bye bye  . Aaron
AKA NVS SVT
Yeah it's modded
Posts: 785 |
in my case i need to pull out the clutch/tranny tuesday to see what going on... my car sitting at my father's garage since about 5week now... but since i got 10$ hour labor... i have no other choice then waiting
so i know how you feel...
MSDS Heaser/Y-Pipe
Magnaflow #10435
9mm Ford racing
HERE
