Posts: 1,029 |
I searched and had a bit of trouble finding the size of the nuts that hold the y-pipe to the rear ehaust manifold. Both nuts are rusted to s**t, but the studs on the manifold itself look ok. What size nut should I get to fit the studs, and will any nut work, or is there anything special about them I need to know. Thanks.
Scott
Mabe I WILL be Phil.
1999 Contour SVT, Tropic Green
BAT kit, K&N RU-3530+MAF, Magnecore 8.5mm, some audio goodies, Hightowers, Knauberized, tatoo by Parkedcar.
Posts: 503 |
this probally won't help much, but I just grabbed a few nuts outta the drawer at the shop and put on the one that fit, so any should work. I also used the same studs. Of course, this is after we caught a welder on fire twice, so I may not be the best person to respond.
95 LX-with a mind of its own
24v DOHC
SVT exhaust and K&N=all thats worth modding
Go Fighting Sioux!!!
Posts: 702 |
I Cant remember for sure but I believe they are either 14 or 15 mm nuts. Not sure of the inside diameter...12mm perhaps?...
CSVT E0 3L
14.5 @ 94mph, Stock Intake, Stock Exhaust minus Resonator, CEL, And Broken Pass. Side CV...Untuned.
Posts: 3,637 |
Originally posted by Pale Horse: I Cant remember for sure but I believe they are either 14 or 15 mm nuts. Not sure of the inside diameter...12mm perhaps?...
15mm
230.2 WHP @ 6500
237.0 WTR @ 2250
much like your weiner.
Posts: 1,029 |
Thanks, but I need to know what size nut to look for in the store, not to get it off. They sell nuts in sizes M-12, M-8, etc.
Scott
Posts: 2,007 |
I'm almost certain that the nuts which hold the front manifold to the y-pipe are M10 x 1.5
Mine were rusted insanely as well. The stealership i went to couldn't find them on the computer. Went to a couple stores to try and find one....one guy referred to the nut as a "jam nut" apparently its kind of like a locking nut. My dad works for ford, luckily he was able to find me a replacement at one of the labs.
1998 Mystique LS:
-2.5 Duratec ATX
-Vibrant White
=Pics=
=Info=
Posts: 1,029 |
I think you're right. Will be replacing them in a few minutes, so I'll let you know for sure. Thanks
Scott
