#1599140 06/27/06 12:15 PM
I woke up this morning to go to work and my 98 CSVT will start but wont idle? I have the P1131 code at present, but never had this problem before. Battery seems fine. When it starts i have to keep pumping the gas for it to stay on, when i let off it just dies. No strange knocks or other noises coming from the engine bay? Please help...
98 Black Contour SVT, #2386 of 6535 How can you live without CEG?
#1599141 06/27/06 12:43 PM
P1131 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 1.
seems that you might need a new O2 sensor but that shouldn't have anything to do with the engine idle
I would check the IAC to start
#1599142 06/27/06 01:23 PM
You can try cleaning the IAC, but be prepared to replace it if cleaning does not fix the lack of idle control.
The P1131 is not related to this symptom.
Steve
#1599143 06/27/06 04:23 PM
I called up a few auto parts stores and found AutoZone has an IAC valve for $37. So i called up Ford and they said they can order one for $110, part #9F715. I am not sure the autozone valve is correct. anybody know where to get one cheaper? i read a few posts on here saying these valves are not meant to be cleaned?
#1599144 06/27/06 04:48 PM
Plenty of people have cleaned IACs and used them with no issues. Clean it, let it dry thoroughly and see what happens.
Capitol CEG Classifieds Make an offer! 2005 GTO IBM - 337hp/336tq
#1599145 06/28/06 01:24 AM
I cleaned the IAC valve today with B-12 and a fine paint brush. It looked pretty dirty, but wasnt horrible. Also, cleaned MAF and TB. Put everything back together and she idles fine. Just curious, how important is it to line up the larger holes on the IAC gasket when re-installing? It has a little bit of play and when both bolts where back on i couldnt tell how centered it was. I took the car out for a test drive and it seemed just ok. I noticed a slight lag in powerband. Will it take the computer a little while to adjust? Thanks for the help...
#1599146 06/28/06 01:52 AM
" Just curious, how important is it to line up the larger holes on the IAC gasket when re-installing? It has a little bit of play and when both bolts where back on i couldnt tell how centered it was. I took the car out for a test drive and it seemed just ok."
If it is not leaking, you should be fine. If it is leaking, you will know (crappy idle again).
"I noticed a slight lag in powerband. Will it take the computer a little while to adjust?"
Yes, give it a day or two.
