Ok im bout to do a 3.0l swap out of a 01 escape. Ive been looking round in here and alot of people have posted alot of thin gs about the part numbers and what is needed. Will someone just pleaase go over this that has done the swap and add to this or just go over this and show me what exactly is needed bc the m ore i scrolled down i just kept findi;ng more part numbers and just got confused. So if someone would just tell me what i need on the list and add/subtract from it i would greatly appreciate it. THANKS! Also i have bout a complete engine of a 3.0l 01 escape already. I printed off this:
I have found all the Fel-Pro gasket I have used to be better quality then the OEM. I added in a few measurements; I have more.
I am very impressed with the Fel-pro parts. Also most of the gaskets are larger than OEM so they accomodate porting perfectly.
Sorry for the repeats as I just cut and paste.
Part Numbers
Fel-Pro Part# CS9038 2.5L Conversion Kit (includes oil pan gasket, oil seals etc)
Fel-Pro Part# HS9038PT 2.5L Head Gasket Set
Fel-Pro Part# 9038PT 2.5L Left Hand Head Gasket
Fel-Pro Part# 9039PT 2.5L Right Hand Head Gasket
Fel-Pro Part# 9540PT 3L Left Hand Head Gasket
Fel-Pro Part# 9541PT 3L Right Hand Head Gasket
Fel-Pro Part# ES72159 Head Bolt Set (2 req.)
Fel-Pro Part# MS92586 3L Plastic Oval Port Intake Manifold Set
Fel-Pro Part# MS95715 Exhaust Manifold Gasket (53mm x 32mm)
Fel-Pro Part# MS95726 2.5L Intake Manifold Gasket Set
Fel-Pro Part# SS72873-1 Valve Stem Seals (Viton)
Fel-Pro Part# VS50462 Valve Cover Set
Fel-Pro Part# TCS45966 Camshaft Rear Seal Gasket Set
Fel-Pro Part# TCS45967 Crankshaft Front Seal
Fel-Pro Part# OS30675R Oil Pan Set
Fel-Pro Part# 61006 SVT TB Gasket
2S7Z-6513-AA ST220 Valve Springs (measured 161-163 lb/in)
YF1Z-6513-FA Duratec Valve Springs (rated 153 lb/in per manual)
3F1Z-6564-AA New Roller Finger Followers
3M4Z-6675-BA Upgraded Oil Pan Set (2 drain back channels and better lower baffles ? comes with gasket and hardware)
4F1Z-6065-AA Head Bolts
F3LY-6214-A Connecting Rod Bolts
F5AZ-6700-A 3.0 Front Crankshaft Seal
F5AZ-6701-A 3.0 Rear Crankshaft Seal
F5DZ-9E936-AE SVT TB Gasket
F5RZ-2A411-A 2.5L UIM Plastic Retainer Grommet with Brass Insert Sleeve
F5RZ-2L181-AA 2.5L UIM Plastic Retainer Grommet
F5RZ-6020-A 2.5 Right Front Timing Cover Gasket
F5RZ-6020-B 2.5 Center Front Timing Cover Gasket
F5RZ-6020-C 2.5 Left Front Timing Cover Gasket
F5RZ-6584-B 2.5 Right Valve Cover Gasket
F5RZ-6584-C 2.5 Left Valve Cover Gasket
F5RZ-9439-B 2.5 Lower Intake Manifold Gasket
F5RZ-9H486-BA 2.5 Upper Intake Manifold Gasket
XF1Z-6051-BA 3.0 Right Head Gasket
XF1Z-6051-DA 3.0 Left Head Gasket
XW4Z-9448-AA Duratec Exhaust Manifold Gasket (50mm x 26mm)
YL8Z-6622-BA 01+ Upgraded Windage Tray (req 01+ main studs)
YL8Z-6687-AA 01+ Upgraded Oil Pickup (req 01+ main studs)
F5RZ-17285-AA MTX-75 Speedo Gear
F7RZ-4211-AC Differential Bearings (2 req)
XS8Z-7230-DD 1-2 Shifter Fork, Roller Bearings (02+)
YS2Z-7230-BA 5-R Shifter Fork, Revised (00)
YS4Z-7230-AD 3-4 Shifter Fork, Modified Oil Scraper (01+)
YS4Z-7K453-FA Shifter Retaining Clip
XS4Z-7201-CD Upgraded Shifter Tower (03+)
BCA part# 3909 Crankshaft Oil Seal
BCA part# 5277 Crankshaft Oil Seal (Teflon)
BCA part# 99363 Crankshaft Oil Seal (redi-sleeve)
BCA part# 88187 Harmonic Balancer Sleeve
BCA part# 482041N Oil Seal, Front Timing Cover
BCA part# 99187 Oil Seal, Front Timing Cover (redi-sleeve)
Spectra Premium# 1719 SVT Radiator
Clevite 77# CB-1772P - Standard, -.25MM, -.50MM, and -.75MM - Rod Bearings
Clevite 77# MS-2207 - Main Bearings
Federal Mogul# 7262MA - Main Bearings
Federal Mogul# 6-4395A ? Rod Bearings
Stant Part# 13396 ? 160 Degree T-Stat
Bosch# 13246 - L1H1 Wideband O2 Sensor
K&N Filters
Tapered Conical - DB x DT x L
RF-1045 (5.5 x 4 x 8) = 720cfm
RC-4630 (5.5 x 4.5 x 6.5) = 615cfm
RE-0950 (6 x 4.625 x 6) = 605cfm
RE-0920 (6 x 4.625 x 9) = 900cfm
RU-3530 (5.375 x 4.375 x 7) = 645cfm (3.75" flange)
Straight Conical - D x L
RU-1785 (5 x 8.5) = 800cfm
Rotunda Tool Set - Essential
T94P-6136-AH Connecting Rod Guides
T94P-6256-AH Camshaft Seal Protector
T94P-6256-BH Camshaft Seal Replacer
T94P-6256-DH Camshaft Damper Replacer
T94P-6312-AH Water Pump Pulley Remover/Replacer
T94P-6312-BH Water Inlet Tube Replacer
T94P-6510-BH Valve Guide Replacer Adapter
T94P-6510-CH Valve Stem Seal Replacer
T94P-6256-CH Camshaft Alignment Triming Tool
T94P-6510-AH Valve Stem Seal Remover
T94P-6510-DH Valve Guide Replacer Adapter
T94P-6565-AH Valve Spring Compressor Adapter
T94P-4451-AH Measuring Fixture
T94P-4451-BH Differential Shim Selection Tool Adapter
T94P-7025-BH Multi-Bearing Cup Replacer
T94P-7025-CH Differential Drive Shaft Seal Replacer
T94P-7025-DH Selector Shaft Bearing Remover/Replacer
T94P-7025-EH Pinion Spline Socket
T94P-7025-FH Gear Lever Aligning Tool
T94P-7025-GH Differential Bearing Cone Replacer
T94P-7025-HH Selector Shaft Seal Remover/Replacer
T94P-2100-AH Sub Frame Alignment Pin Set
T94P-6000-AH Power Train Alignment Gauge Set
T94P-70010-AH Transmission Range Sensor Tool
